Old 07-12-2020, 09:17 AM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Help fix this leak. Lots of pictures
So, here's the deal. We've got the shell back on our 92 Excella. We're stripping the old caulk off the back of seams etc. We're also finding some areas that have been leaking as evidenced by either missed or corrosion. Anyway, the plan is to replaced all of the caulk we're removing with Tremco's Trempro 635. A few of the areas we need to seal are gaps where the front window and the curved windows come together. I'm thinking of back filling them with Trempro and then front filling them with Parbond Aluminum for esthetics.
Besides the gaps at the windows we've also found a number of holes that were factory drilled or should I say misdrilled and because of access challenges never received a rivet and we're simply filled with caulk. And in one case where the antenna was moved, (possibly by a PO) to install the street side awning, they covered it with an emblem. I even found at least one unfilled rivet hole in the ceiling that was caulked. It did not appear to have leaked. For sure some did leak and some didn't. Out goal is to properly fix them all.
Any advice on the best way to repair / seal these is welcomed as well. Click image for larger version
ID:	372649Click image for larger version
ID:	372650Click image for larger version
ID:	372651Click image for larger version
ID:	372652Click image for larger version
ID:	372653Click image for larger version
ID:	372654Click image for larger version
ID:	372655Click image for larger version
ID:	372656Click image for larger version
ID:	372657Click image for larger version
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500
Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Restoring our Caravel Land Yacht - lots of pictures Caddyshack General Repair Forum 20 07-30-2024 05:09 PM
1977 Airstream Overlander 27' with title, nice, lots of pics,lots of new updates eBay Watch Airstreams on eBay 0 06-15-2012 09:50 PM
'86 Excella 34' water tank help (lots of pictures) Atomichoe094 Water Heaters, Filters & Pumps 6 06-26-2011 10:06 AM
my 31' 1982 Limited up for sale in Austin TX....lots of pictures! MaryContrary 1982-1983 Limited 5 08-28-2009 04:24 PM
