Old 11-30-2018, 08:45 AM   #1
2016 30' Classic
Victoria , British Columbia
Help finding leak
We have a very small interior water leak that is dripping from the door side edge of the over bed cabinet, falling onto the bedside tabletop. It is a very small leak, whereby a full day of heavy rain will produce less than a shot glass of water. As it is higher than the windows, it must be coming from the roof area. I have checked all the caulking, and there does not appear to be any issues. I have recaulked around the marker lights, but that has not solved the problem. Iíve also pulled the interior AC intakes and vents, and those areas are dry. Out of desperation, I am wondering if the Airstream letters on the rear exterior are glued on, or are they attached with a pin that inserts through a hole in the skin for each letter? Any ideas would be greatly appreciated.
Camr is offline   Reply With Quote
Old 11-30-2018, 09:27 AM   #2
1996 25' Excella
Tillsonburg , Ontario
Double check the AC seal to the roof
I had a leak under the drip pan due to the AC being hit. Eater showed up over the stove. I just caulked heavily under the pan to correct the problem.
JCW
JCWDCW is offline   Reply With Quote
Old 11-30-2018, 09:30 AM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
The letters are glued on. Check around the roof vent for loose or bad caulking. You possibly have a rivet leaking, and Captain Tolley's creeping crack cure is the solution for that. Also check the caulking around vent stacks. I have also found leaks where the awning mounts to the body. Happy hunting!! Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is online now   Reply With Quote
Old 11-30-2018, 09:31 AM   #4
Gresham , Oregon
Help Finding Leak
Make sure you have sealed the marker lights all the way around. Also, check the marker lights to determine if they are taking in water through the lens. You will be able to see the water inside the lens if it is taking in water. Once inside the water will be able to enter the trailer through the screw holes and the holes where the wires pass. I had to seal the lenses using a clear caulk. I plan on changing the marker lights to LEDS which should seal better than the old ones. Hope this helps.
skido23 is offline   Reply With Quote
Old 11-30-2018, 09:44 AM   #5
2016 26' Flying Cloud
Southlake , Texas
Get a small suction cup and check all rivets. If the cup doesn’t hold suction, you have a leak. Seal with Capt Tollys.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
Old 12-03-2018, 10:37 AM   #6
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi Camr,*
We're sorry to learn about the leak you are having. If you need assistance, please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Need Help Finding Leak in New Airstream badfish_2 General Repair Forum 10 02-02-2017 06:47 AM
Help finding leak from wall coming in to left of windows batt Windows & Screens 15 05-04-2016 08:24 PM
Old PB Tee Connector Leak, need help finding replacement! Rhino33 Fresh Water Systems 5 07-30-2014 09:20 AM
Mystery leak - NEED HELP finding it pgreenx Plumbing - Systems & Fixtures 2 05-30-2012 06:44 AM
Wet floor, finding & stopping leak Joseph O. Smith Repairing/Replacing Floor &/or Frame 4 03-24-2003 10:17 PM
