Old 03-07-2022, 04:03 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Help finding 3" wide single sided butyl tape
So I stripped off the old, put it on 15 years ago, butyl tape from around my air conditioner, now wish I had not done that, I can not find any 3" wide butyl tape with a coating on one side, well I have found tape with a foil of fabric coating. Can anyone recommend a 3" wide tape with a plastic coating on one side, can't find the old stuff I used before which was really good stuff.
Bruce,
Parts needed: Sink for rear bath Tradewind
My blog for the 1975 Tradewind restoration
bmklawt is offline   Reply With Quote
Old 03-07-2022, 04:10 PM   #2
dznf0g's Avatar
Oswego , Illinois
Eternabond doesn't make 3"????
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
Old 03-07-2022, 04:12 PM   #3
dznf0g's Avatar
Oswego , Illinois
https://www.amazon.com/EternaBond-RS...673&psc=1&th=1
Scroll down for 3"
-Rich-
flexible molding double sided tape suggestion stephes1 Off Topic Forum 3 04-26-2020 02:34 PM
butyl putty tape on the roof bacevedo Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 02-22-2009 05:09 PM
Source for pre-shimmed butyl tape pnb77 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 04-09-2008 09:48 AM
Seeking advice on replacing butyl tape sealant on ridged aluminum SOB SilvrSausage Vintage Kin 0 09-22-2007 11:03 PM
