Please take a look at the pictures. Should the doors be lined with foam trim which has disintegrated or rubber seals? Not sure if the foam was original or replaced something mush sturdier. The foam has been used on all the outer storage doors.
On mine foam is original. I tried to use rubber with less than satisfactory results. Removed the rubber and replaced with the proper foam from vintage trailer supply.
MICHAEL
