Old 04-23-2017, 06:39 PM   #1
CallDon's Avatar
1986 Argosy
Dallas , Tech-Sus
Flextape on a roof seam?
QUESTION:
Has anyone used Flex tape or Flex Seal to repair their Airstream, on the roof or on any leaks or to hold something together?
It seems like Flextape might work on a leaky roof seam. That's what I'm thinking.
CallDon is offline   Reply With Quote
Old 04-23-2017, 07:22 PM   #2
1990 32' Excella
jonesboro , Arkansas
Used it for the first time yesterday on a boat cover. Patched a quarter sized hole ins boat cover then towed 150 miles at 70 mph. Held well on canvas and vinyl. If you have a white top you could prob use it. I would go with a aluminum and mastic HVAC tape if you have an aluminum top. I know the alum tape works . I have used it many times. Good luck.
joel is offline   Reply With Quote
Old 04-23-2017, 09:51 PM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
So is your trailer the SquareStream on your photo? Whatever, I don't think a tape, and I've used several on various projects over the years, will be more than a temporary fix, and difficult to remove after it's life has ended. Best solution would be to find the source of the leak and patch with a product like Sikaflex, seal it up and then monitor it.
DryFly is offline   Reply With Quote
Old 04-24-2017, 06:07 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I've read others have used it on their roof but if you suspect a leaky seam and can reproduce the leak by running water on the seam I'd duct tape the seam, run water and if the leak doesn't appear then pull about 6" of tape off and apply water. If the leak appears after exposing the last rivets then you can concentrate on sealing or replacing those rivets then retest.
Kelvin
Old 04-24-2017, 12:53 PM   #5
2010 25' FB Flying Cloud
I have use a 3M seal tape on my 25' airstream which had a big leak over rear roof rivet joint. Stopped the leak!!! Have read others who say will last for a decade (we shall see). Best if you use a small paint roller to apply additional pressure. Stuff is pretty cool.
Name on amazon:
3M 4412N 2.95275590551 181in X 5yd Sealant Tape (1 Roll)
Anders79 is offline   Reply With Quote
Roof redux: Fixing T1N seam rust InterBlog Sprinter and B-van Forum 27 05-20-2018 07:37 AM
Sealing the roof seam dfschultz Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-12-2015 02:21 PM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
dented roof panel, with popped seam, Hard Fix?? dkutz Roof 3 02-13-2006 11:27 AM
