Old 01-06-2017, 03:58 PM   #1
Registered User
Grand Bay , Alabama
flex seal on airstream travel trailers
Has anyone used flex seal to seal the roof seams, around the windows and window seams and the seams around the door, if so how good of a job does it do?
spoonplug is offline   Reply With Quote
Old 01-06-2017, 04:12 PM   #2
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
I used it on the inside of my fathers attwood water heater door. It had rusted due to an untended leak from the drain plug. Used black flex seal to reprint after rust was removed. Worked great!
Old 01-06-2017, 04:17 PM   #3
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I don't think I would consider trying their spray can stuff, I think it would make a real mess unless you masked everything really well.
They sell another product that looks likes some sort of caulk in a pressure can - I had though of maybe getting a bit more info on that. Even there though I would have some concerns (apart from how well i seals.)
(1) how well can you control it when being dispensed?
(2) after using it once, does the can get plugged up to the point of being un-usable the way those spay insulating foam cans sometimes do?
Not too much wrong with Acryl-R in its dispensing gun for the thin self-wicking applications and polyurethane caulk in cartridges for everything else (sikaflex and similar). Easily applied and smoothd in place with a finger.
I should keep an open mind though and certainly defer to anyone who has used Flex Seal!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 03-05-2017, 11:39 AM   #4
Sun Rae
jack9443's Avatar
1977 Argosy 28
Lewisburg , Tennessee
I saw someone using the clear flex seal liquid 16 oz can on the rivets vents and seams on the roof he said it worked great I have tried the liquid white in shower pan and the white roof we will see how works
jack9443 is offline   Reply With Quote
Old 04-09-2017, 07:36 AM   #5
1973 31' Sovereign
Ashburn , Virginia
flex seal
We used flex seal in a spray can all over the inside of our airstream shell because we had a ton of leaks coming from leaky rivets and the seams where the aluminum meets. It worked amazing and has held up perfectly for the last 6 months so far. We've had really heavy rains and we are totally dry inside. Ive even had a heat gun on the flex seal and it did not change at all.
Elissasteele is offline   Reply With Quote
Old 12-26-2017, 11:38 AM   #6
Sun Rae
jack9443's Avatar
1977 Argosy 28
We used 2 quarts of white on the top it was already white but no leaks anymore 1977
Old 02-24-2019, 04:16 PM   #7
Laff67safari's Avatar
1967 22' Safari
Zanesville , Ohio
I made a boat with it.
Laff67safari is offline   Reply With Quote
Old 02-24-2019, 04:18 PM   #8
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Originally Posted by spoonplug View Post
has anyone used flex seal to seal the roof seams, around the windows and window seams and the seams around the door, if so how good of a job does it do?
What? I can't hear you!
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 02-25-2019, 03:02 AM   #9
1973 31' Sovereign
Ashburn , Virginia
Works great
We fixed literally all of our leaks with flex seal. Its been a year and everything looks great! It didn't make a mess, we sprayed it all along the rivets and for the Windows while ours was gutted. Huge fan. Volcom came in handy too.
Old 02-25-2019, 05:51 AM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Ha!! Good one!
2019 Ford Expedition Platinum
Old 02-25-2019, 05:52 AM   #11
Wayne&Sam's Avatar
Images: 21
Posting this in a huge font is kind of like a shouting television commercial.
Old 02-25-2019, 08:17 AM   #12
Sun Rae
jack9443's Avatar
1977 Argosy 28
update on flex seal
update on flex seal after 2 years still good and not covered
Old 02-25-2019, 08:19 AM   #13
turk123's Avatar
2019 30' Classic
Canfield , Ohio
What?
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
2017 Airstream International Signature 27FB Twin
2019 Airstream Classic 30 Twin
Link to our shared album: https://photos.app.goo.gl/wACfGg1KcroVLP5m6
turk123 is offline   Reply With Quote
Old 02-25-2019, 08:39 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The tube flex seal is basically silicone.
Installing exterior lights-to seal or not to seal Belegedhel Lights - Interior & Exterior 7 10-26-2013 07:14 AM
Flex Seal- As seen on TV submariner Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-02-2012 03:29 PM
To 'seal' or not to 'seal'?? b8sfamily Floor Finishes 6 03-31-2009 06:13 AM
Vertical lip seal and trim seal for Classic Motorhomes rdm General Motorhome Topics 16 05-22-2006 07:49 PM
