Old 09-12-2017, 08:08 AM   #1
rpm750's Avatar
1988 29' Excella
Newnan , Georgia
Stationary Window Leak
I have searched and I guess I'm not using the correct terms. During Irma I went out and checked for leaks in our AS. I have been replacing some sub floor and thought I had found all the leaks in the areas of damaged sub flooring.
I found the fixed window on the right of the door leaking. Turns out after removing all the inside panels again that the caulk seal between the glass and frame have come loose. The glass is not in a complete frame just the outside face of glass is caulked to the frame. The edge of the glass all the way around was damp with the bottom portion allowing water to run in.
My question is what is a proven way to remove the glass from the frame so I can install new material to secure the glass with no leaks? I will remove the old caulk from the frame of course. I don't want to break the glass.
Thanks Bob
rpm750 is offline   Reply With Quote
Old 09-12-2017, 08:35 AM   #2
dznf0g's Avatar
Oswego , Illinois
Pics of the mounting methodology would help. From your description, I think the mounting is like my front curved pano windows. If so, I do have successful experience with that repair.
-Rich-
Old 09-12-2017, 09:03 AM   #3
rpm750's Avatar
1988 29' Excella
Newnan , Georgia
The design looks the same as the Panos.
This shows the good corner. You can see the caulk squishing out from the back. An angled Xacto chisel blade would be nice to have. The caulk looks like the grey material that AS used on all the interior sealing.
Thanks Bob
Old 09-12-2017, 09:08 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by rpm750 View Post
Attachment 294672
Thanks Bob
The grey stuff is Vulkem. It is a polyurethane caulk. The consensus is don't use silicone. Vulkem may not be out there anymore but Tempro has a replacement.
Old 09-12-2017, 09:12 AM   #5
dznf0g's Avatar
Oswego , Illinois
OK, it appears to be a little different than mine, but since yours is a pretty old trailer, it is probably best to remove and replace all the sealer. ( I was able to repair a small corner area in mine). If I see the pic correctly, I would try and dig out a half inch or so, from the inside and outside) and work a thin piano wire from inside to outside. Then, with a helper, work the wire back and forth, "sawing" the sealer around the perimeter. Clean VERY well and reseal with Sikaflex 221 UV. (IIRC, I'm not home right now to check the Sika number)
-Rich-
Old 09-12-2017, 09:17 AM   #6
dznf0g's Avatar
Oswego , Illinois
Oh, and when you set the window glass into the new sealer, You should devise some way to apply and hold a bit of pressure on the glass. I don't think just taping it in place will adequately hold it until the sealer cures.
-Rich-
Old 09-18-2017, 06:06 PM   #7
rpm750's Avatar
1988 29' Excella
Newnan , Georgia
Okay I got the window out without breaking it. And I've dug most of the old caulk out. There is a groove all the way around as well. This makes this hard caulk very hard to get out. Before I caulk it back in a away to hold it in place so it has an even seal on the outside lip.
What caulk material would work best? I have Trempro 635, will this work for the long term? I want to do this right.
Old 09-18-2017, 06:13 PM   #8
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
that what I used and is suggested. Rock on bro!
Matt
rugjenkins is offline   Reply With Quote
Old 09-24-2017, 08:59 AM   #9
rpm750's Avatar
1988 29' Excella
Newnan , Georgia
I came up with a support system. This held the window in place while the caulk dried.Click image for larger version
Old 09-24-2017, 10:04 AM   #10
1981 31' Excella II
New Market , Alabama
You sure this was not a double pane window that the inner pane was removed and the outer pane was just caulked back in? My 81 has that same window by the door and it leaks between the panes. I had a leak at the frame gap at the bottom and cured that with caulk and removed the gray plastic gasket and replaced it with Trempro 635 which has not held up well. It should have been held in my a gasket not caulk if it was factory.
Perry
Old 09-24-2017, 07:51 PM   #11
rpm750's Avatar
1988 29' Excella
Newnan , Georgia
Not a double pain. There are two smaller windows that are constructed the same. There was not as much original caulk on this one as the others. The Trempro should be good for a few years.
Water lnlet Pipe Leak - Fixed TankerIP Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 08-28-2012 08:24 PM
'76 Airstream GT Fixed Window Leak kentuvman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-11-2012 08:25 PM
Fixed Window Leak Problems perryg114 Windows & Screens 10 01-27-2012 11:42 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
I fixed my leak, with help from the Capt. Air-13800 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 10-24-2007 10:08 PM
