Old 03-31-2021, 03:16 PM   #1
Peter417's Avatar
1966 17' Caravel
1972 21' Globetrotter
SW , Missouri
Fantastic Fan and AC Leaks
My fan and AC were both sealed about 10 years ago. I am not sure what was used. Parbond is my best guess. It is gritty feeling and cracked now.
What should I use to reseal these? Should I use butyl tape on the fan?
ID:	392091   Click image for larger version
NWA MTB
Peter417 is offline   Reply With Quote
Old 03-31-2021, 03:42 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I just cleaned all the old 'caulking' off the vent cover and roof and re-sealed with 3M Extreme Sealing Tape, 3in/W
8+ years SFSG.👍
Website
ID:	392093   Click image for larger version
Obrigado, ť hora de descansar.
Tahawus
Old 03-31-2021, 03:52 PM   #3
Peter417's Avatar
1966 17' Caravel
SW , Missouri
8+ years SFSG.👍
Website
Thanks Bob. I was hoping for an option like that. Do you have any experience with any of the foil backed tapes? I wonder if the foil would protect the tape almost indefinitely.
https://www.amazon.com/Repair-Covere...07F9JS61R&th=1
NWA MTB
Old 03-31-2021, 04:19 PM   #4
I don't really. But why not give it a try and let everyone know how it works out...the more workable options we all have the better. Butyl without the backing is a known good between panel sealer.
To be perfectly honest the 3m option was only really supposed to be a short term stop gap repair, I had every intention of doing an R&R full monty job.
After a Spring get ready inspection the next season it still looked so good I just left it, it's been 7yrs.
I'll ck it again in a week or so but I don't expect any surprises.
Tahawus
Old 04-01-2021, 09:24 AM   #5
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I've had Trempro 635 get that gritty feel on the surface after a few years. I like Sikaflex because it stays flexible and shiney.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-01-2021, 09:28 AM   #6
2019 23' Flying Cloud
Waterford , New York
What Bob Said!
Just make sure what ever you use is compatible with aluminum. I believe itís sealers with a high carbon content will cause crevice corrosion.
Larry1492 is offline   Reply With Quote
Old 04-07-2021, 12:15 PM   #7
Peter417's Avatar
1966 17' Caravel
SW , Missouri
Things are dry after the first good rain
NWA MTB
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
