Old 10-05-2017, 11:21 AM   #1
Wanderlust61's Avatar
1975 Argosy 28
Tyrone , Missouri
Entry door
The hing has a gap between it and the wall. I can't get the screws to tighten. They turn freely in the holes. There seems to be a screw or rivet going into the back of the hing, from inside the wall.
Is there supposed to be a gasket between the hing and wall?
As I put it back together, should I caulk it?
Wanderlust61 is offline   Reply With Quote
Old 10-05-2017, 11:22 AM   #2
1975 Argosy 28
Tyrone , Missouri
Old 10-05-2017, 11:38 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You will need to gain access from the interior side.
Many use a hole saw.
The nut is spinning on the bolt inside the wall.
It is either a hole to gain access or the removal of the interior skin.
Old 10-05-2017, 11:41 AM   #4
1975 Argosy 28
Tyrone , Missouri
Thank you. I will try to open the wall before I cut into it.
Old 10-05-2017, 04:52 PM   #5
1979 23' Safari
Wayland , New York
If there is enough space you may be able to remove rivets from the interior skin around the door and gently pull them in enough to get access to the nuts. The his approach requires removal of the door trim. Apply sealant around the gap before tightening, it'll squish down to seal better. If you get good access to where you can actually remove the screws, squirt some sealant in the exterior hole to help seal the screw penetration.
Old 10-05-2017, 06:13 PM   #6
1975 Argosy 28
Tyrone , Missouri
Old 10-05-2017, 06:15 PM   #7
1975 Argosy 28
Tyrone , Missouri
Old 10-05-2017, 06:20 PM   #8
1975 Argosy 28
Tyrone , Missouri
ID:	296324Click image for larger version
ID:	296325Click image for larger version
Old 10-05-2017, 06:24 PM   #9
1975 Argosy 28
Tyrone , Missouri
I replaced the screws, caulked and tightened it all back together. I hope this stops the leak.
Old 10-05-2017, 07:45 PM   #10
1979 23' Safari
Wayland , New York
Nicely done.
Sometimes thread lock doesn't work well on stainless steel hardware, if you put a second nut tight on top of the first one it's a good backup.
When I replaced my interior skins I cut notches like the ones you did from the get go and slightly overlapping panels to cover them so any future access would be easy.
Old 10-06-2017, 01:37 PM   #11
1975 Argosy 28
Tyrone , Missouri
Thank you all for the help.
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Airstream outside entry door with screen door & trim netlace Doors & Locks 1 10-02-2009 05:53 PM
entry door handle lido&linda 85/345 General Motorhome Topics 14 06-27-2006 05:46 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
