03-28-2021, 06:10 PM
1975 Argosy 26
Hanover
, Pennsylvania
Dirt Sticking to Trempro 635
Hi,
I need a suggestion for an exterior sealant for seams, rivets, windows, that dirt and road grime will not stick to. It will not be painted over.
I’ve used trempro 635 for the entire project so far. Dirt and grime stick to this stuff like crazy and it doesn’t wash off. Thankfully we re-sealed everything new and painted it right away (photo attached).
Please suggest a finish top sealant for windows and seams that is washable, that cures without tack, that comes in white or gray or clear.
Thanks in advance!
03-28-2021, 06:30 PM
1966 22' Safari
Fredericksburg
I’ve never thought about washable before. I have used MasterSeal NP1 for decades on houses and our Airstreams. It is a polyurethane and considered washable. You may want to get a tube and run a bead of caulk on a board and let it cure. Rub dirt on it and wash it to see how it holds up. But it has to cure. To prevent an open tube from drying out, just tape up the nozzle air tight. It’ll be interesting to hear other’s suggestions. Take care and good luck.
03-28-2021, 07:04 PM
1975 Argosy 26
Hanover
, Pennsylvania
Any suggestion on where to buy a tube? Colors?
03-28-2021, 07:24 PM
Overkill Specialist
2020 30’ Globetrotter
2014 23' International
Dadeville
, Alabama
Sikaflex 221
03-28-2021, 07:30 PM
1966 22' Safari
Fredericksburg
Our local Ace Hardware has it. Check online to see if your locals handle it. Since it’s a polyurethane, others may work as well. It’s not expensive, so give it a whirl.
03-29-2021, 02:04 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Airstream and I use Adseal. it its siliconize sealant, but ok to use on aluminum. It is easy to apply and remove. Airstream says to reseal your trailer every 5 years.
guskmg
03-29-2021, 03:03 PM
1974 Argosy 26
Langley
, British Columbia
Gorgeous Paint job ! I am slowly prepping for paint this spring ... Also keeping the aluminum unpainted on the frames , love the contrast . I don’t know about sealant ... I just used trempro 635 on a bunch of spots as I didn’t realize it would get dirty ! Would love any tips you have on painting !
03-29-2021, 03:32 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Narrow gap seals around windows, panel seams & such?
The Captain has always worked for us. It may take several applications but they are quick & easy...and the stuff does work. Its idivisibabel, plus 'ya can't see it.🥴
Sooper looking rig BTW
04-01-2021, 09:32 AM
1986 25' Sovereign
Southern Middle
, Tennessee
I second Sikaflex 221. It seems to stay flexible. I have some sealing to do on panels and will use Alcoa gutter seal for those while using Sikaflex on the vent stacks and Fantastic Vent Fans. Later in the summer I will be scraping off all the Trempro I put around the front windows because it has that black mold and dirt.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Alternatives to Trempro-635
perryg114 |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
3 |
08-24-2021 03:17 PM |
Trempro 635
TravisA |
13 |
06-11-2019 11:49 AM |
Rear End Gap - Sealing over Trempro 635 with Eternabond
jami20 |
0 |
11-10-2015 09:30 AM |
TremPro 635 vs. Loctite PL S-40
OffTheCouch |
2 |
09-29-2015 11:14 AM |
TremPro 635 -vs- OCI QUAD -vs- OCI H2U
grndslm |
11 |
05-19-2015 07:33 PM |
