Old 03-28-2018, 10:43 AM   #1
wecoyote's Avatar
2014 30' Flying Cloud
Royal Oak , Michigan
Check here for leaks
Here is a new place to look for leaks!
Our 2014 30' FC had floor issues the first season after bringing it home. There was discoloration of the flooring around the bed and a small area near the front sofa. Our dealership was very apologetic and replaced the floor with no cost to us. The went over the roof and make sure all possible cracks were sealed (even though it was a new camper).
The following season, the flooring was discolored yet again, even worse than before. As you can well imagine, we were very dissatisfied!
That brings us to this past winter. Over Thanksgiving weekend, we took it to the dealer with the comment "We don't want it back until it is fixed for good!".
After much searching, they found the TRUE reason for the floor rotting. There was a leak along the seam where the upper and lower panels come together as well as along the center trim piece.
They had to pull the entire center trim piece off and re-seal the upper and lower panels as well as re-do all of the sealant on the center band.
When they were replacing the floor for the second time we took the opportunity to replace the cheap vinyl flooring with Marmoleum Striato Textura
Our maiden voyage will be Florida for spring break leaving this Friday (3/30). Fingers crossed!
Royal Oak, MI
WBCCI #: 8356 (the same number my grandparents had from 1963 to 1981)
AIR #: 104322
Henry - 2013 F150 Super Crew XLT w/ HD Towing
wecoyote is offline   Reply With Quote
Leaks, leaks, and more leaks da_lizard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-11-2016 11:36 AM
LEAKS LEAKS more LEAKS in ATL parzam21 General Repair Forum 17 12-27-2015 02:46 PM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
