Old 09-12-2020, 03:20 PM   #1
1979 Argosy Minuet 7.3 Metre
Madill , Oklahoma
caulk on bare inside walls questions ????
We have everything out. We want to caulk around old windows, doors, seems, and rivets. We are replacing caulk and are adding new.
? One. Does anyone know what the original caulk was or is?
? Two. What kind of caulk do I need to use?
By any chance does it come in a bucket?
Thank you, and have a great day.
Little city is offline   Reply With Quote
Old 09-12-2020, 05:51 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Just about everything you need to know is found here, but, of course, this being the forums there are more opinions than avatars and threads abound:
https://www.airforums.com/forums/f45....html#post5693
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 09-13-2020, 09:32 AM   #3
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
Don't use normal caulk on your airstream! One of the biggest pains in tearing down an airstream for a rebuild is removing 50 years of caulk upon caulk upon caulk from previous owners (unsuccessfully) chasing leaks.
Here is a link to the proper "goos" for all things Airstream...
https://beahmstream.com/all-kinds-of...-leak-sealers/
But the most important thing is dealing with issues properly, not just slapping goo over the top of something and *hoping* it works. Butyl tape between layers of metal is often the proper way to seal something up, but that requires disassembling things, sealing them properly, then putting things back together. It's like your grandpa always said: do it right the first time!
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 09-14-2020, 01:20 PM   #4
Madill , Oklahoma
Thank you for the link,Sir. I will definitely read those and all help is appreciated.
Old 09-14-2020, 01:27 PM   #5
Madill , Oklahoma
Well I was Wondering if anyone else tore out all that caulk. So this makes me feel better. Yes we are tearing out and also replacing,also using butyl tape, and trying very hard to do it correctly. Not that we will have it for another 50 years but it might be around. Thank you for the advice.
Bare walls, what to do. Silver Speak Upholstery, Blinds, Walls & Interior Finishes 8 08-20-2018 01:49 PM
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
