Old 12-21-2020, 12:17 PM   #1
1977 31' Excella 500
Spring , Texas
Best Way to Remove Old Adhesive From Panels?
What would be the best product to use to strip and prep the panels for installation and sealing?
There is old adhesive and silicone left behind from the old patch job done.
1977 31' Excella 500 full restoration: Excella 500 Off Road Build
GPurcell is offline   Reply With Quote
Old 12-22-2020, 08:22 AM   #2
Spring , Texas
No one?
Old 12-22-2020, 09:13 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I'm someone...
The best thing I have found to remove tape adhesive is "Bestine". For Silicone I've found the "Permatex Gasket Remover" works pretty well. Silicone is a bear to remove completely....usually, there are some choice %#$@*! words involved.
Both can be found locally as well...
Good luck!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-22-2020, 09:32 AM   #4
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I use this, https://goofoffproducts.com It works well and does not hurt the AS coating.
Check this out as well.
thewarden is offline   Reply With Quote
Old 12-22-2020, 10:18 AM   #5
1976 31' Sovereign
Oswego , Illinois
Be aware goof off will remove clear coating older AS, some claim doesn't on new but it def. will on older AS.
Old 12-22-2020, 10:54 AM   #6
2018 25' International
Slidell , Louisiana
The Bestline solvent works ok on some but not all adhesives. WD40 does a nice Jobe on a wider range. It iis not quit as effective but very similar to GoofOff. It is a bit easier on clear coat. You may want to try it first. As mentioned the gasket removers at least work a bit with silicones and polyurethane flex sealants.
Brian
Old 12-23-2020, 07:39 AM   #7
Spring , Texas
Great! Many thanks. My clearcoat is well FUBAR'd already - if there is any left - so not worried about it.
Old 12-23-2020, 10:32 AM   #8
1976 Argosy 24
1961 28' Ambassador
1968 26' Overlander
Lakewood , Colorado
Hey gang, after 45 years in the automotive industry and dealing with sealants/adhesives and how to remove them on a daily, "in the trenches" basis, here are some of my favorites.... The aptly named 3M General purpose adhesive remover, either spray or quart can, often with 3M scotchbrite red pads. WD40 can be very effective in the right situation, again with scotchbrite or wire brush. Professionals hate silicone sealants because you must remove 100% of it for an effective reseal with the correct product. Nothing is really a solvent for silicone but many can act as an effective lubricant to help speed the job along. I have never heard of or used the Bestline product. GoofOff is way down my list. For old, as in 60's/70's vulkem, I like some judicioius heat with a real heat gun and your scraper of choice. My overall arsenal has dozens of tools and products and trial and error and experience go a long ways towards a time effective result.
Happy scraping... Mark D
mrdes8 is offline   Reply With Quote
Remove Insulation Adhesive ASNomads Upholstery, Blinds, Walls & Interior Finishes 12 01-05-2018 09:28 PM
How to remove number adhesive Bill M. Clearcoat, Exterior Paint & Trim 8 09-07-2016 07:15 AM
How do I remove the adhesive left from stripe GeGe Cleaning, Stripping & Polishing 18 03-04-2015 09:16 PM
Mystery adhesive on patch and how do I remove it? seismicfish General Repair Forum 6 05-07-2014 08:48 AM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
