Old 04-20-2018, 06:25 AM   #1
1973 Argosy 24
Corpus Christi , Texas
Argosy Exterior Seam Sealing
I know this is a topic that's been beat to death almost, but after combing through tons and tons of threads I haven't seen anyone that brought up this question (but it's possible I missed one). I'm curious about sealing leaks on an Argosy from the exterior over paint. We're currently doing a frame on restoration of our '73 Argosy 24 and one of my first major tasks is to make it water tight. I'm in the process of pulling off the skins to seal it from the inside and I'm also thinking I'm going to seal it from the outside as well. Now here's my dilemma: we're eventually going to get it re-painted but I still want to seal the seams and possibly the rivets. Has anyone with an Argosy or painted AS sealed over paint? Or would y'all recommend to buff off the paint along all the seams and then seal the bare aluminum on the seams and then paint over? Has anyone had any experience painting over the sealants? Or if I use Lexel or Capt. Tolley's on it, will that seep into the seams and there shouldn't be anything to paint over when it comes to repainting? I also realize that the paint will help seal to some extent, but I'd rather not rely on the paint as a sealer (because it clearly isn't working right now). With bare aluminum, it's straightforward, but painting over or sealing over the paint is different. I'm just trying to get it done right the first time so I'm not having to redo it again in a couple years and also get it done without needing to get it repainted every time after I reseal it.
ASFmlyTrdshn is offline   Reply With Quote
Old 04-20-2018, 08:11 AM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
I have an argosy also I'm going to repaint. I stripped mine and have been resealing also. All the sealants you name can be painted over. So can sikaflex and gutterseal. Captain tolley on the rivets and sikaflex or gutterseal on the seams and your good to go.
Matt
rugjenkins is offline   Reply With Quote
Old 04-20-2018, 08:37 AM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I scraped the old sealant out of the seams, first. Then taped both sides of each seam to keep excess sealant contained. After the sealant dried and cured I painted. No leaks at the seams. I used SikaFlex fo sealant and Hyperseal for the roof coating.
A couple of notes: minimize the amount of sealant you use - it doesn’t take much. Clean up with paint thinner any excess immediately.
DryFly is offline   Reply With Quote
Old 10-19-2018, 11:03 PM   #4
ScottandMoni's Avatar
1988 29' Argosy
brookdale , California
To dry fly
Hi ~ just joined and need to seal the roof on my 1988 Arogsy ~ just getting info here to decide how I want to do this. Did you seal your entire roof?
ScottandMoni is offline   Reply With Quote
Old 10-21-2018, 10:42 AM   #5
DryFly's Avatar
1972 Argosy 20
Smile
Yes, I sealed every seam on the trailer. I also used Captain Tolly's on the rivets, as rugjenkins suggests. Then the Hyperseal on the roof. Before using the Hyperseal I caulked (Sikaflex) around the vents and fan. The roof is as water tight as an AS can get, I think.
There's a really good thread on sealants that lays out, for the most part, what sealants to use where. I liked the Sikaflex and it's workability, but I've also used Loctite, which may actually be a longer lasting product with basically the same attributes. According to Loctite (I called their technical services line and spoke to a live person), once painted the product will last "indefinitely". Sikaflex won't make that statement - probably a liability thing. The advantages I see for Loctite are that it's available at a lot of places including the big boxes and it comes in many colors. Sikaflex is a little more elusive.
Old 10-21-2018, 11:21 PM   #6
1988 29' Argosy
This is very helpful. We just took all the old caulking off the seams and used a light wire wheel on those areas to get it really clean. All rivets are now exposed as are the seams. I am planning on caulking every rivet with sikaflex, letting them dry and then using permabond tape on all seams and then sikaflex on top of permabond tape. I’d appreciate any thoughts you have on this.
As I read your reply it seems you used one product on the rivets, another on the seams and vets then another for the roof? Or was the hyper seal placed over the sikaflex on the seams?
Old 10-21-2018, 11:22 PM   #7
1988 29' Argosy
I do see that you suggest the loktite over the sikaflex.
Old 10-29-2018, 11:13 PM   #8
1988 29' Argosy
Sealing side panel seams
We have finished our roof and are now moving onto side seam sealing. Planning on using sikaflex on side seams and capt tulley on rivets same as we did on roof ~ just minus the silicone sealing we did on roof. Any other suggestions on another product and/or method for side seams?
Old 10-30-2018, 10:43 PM   #9
DryFly's Avatar
1972 Argosy 20
I think the permabond tape and sikaflex combined is overkill. You need to consider what you'll do in a few years when you need to revisit your roof. I see later down the thread you used silicone - is that correct?
Moving forward, just use either sikaflex or loctite, don't use silicone and really consider whether you want to use permabond tape. Use Captain Tully's on the rivets.
I used the Hyperseal as a finishing coating, so it went on after sealing the seams and rivets. I used Hyperseal because I had some left over from roof repairs I did on a couple of commercial flat roofs. I have faith in the stuff, so I used it and I'm glad I did. Way better than just paint. It's just for a roof though - I'd never use it below a roof line.
PM me if you want more information. I may not get back to you for a few days as I'm on the road. In the interim, throw away the silicone!
Seam sealing from the inside? ironheadxlch General Interior Topics 19 09-04-2015 08:08 AM
interior seam sealing GR8DANE Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-09-2013 11:58 AM
Seam sealer or seam tape silver 67 Ribs, Skins & Rivets 1 07-30-2013 12:53 AM
Need Advice on Seam sealing material nm1oqrz Ribs, Skins & Rivets 4 02-16-2011 11:44 AM
Seam sealing - again Fyrzowt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-08-2006 12:01 PM
