Old 12-16-2018, 04:21 PM   #1
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
Adhesive Question Window Weather Strip '92 Escella
Rebuilding and restoring a 1992 Excella. We have the weather strip / gasket, and 3M Gasket Adhesive purchased from odmrv.com. I was reading the adhesive instructions and "step two" caused me to pause. I'm including a couple of pictures of the instructions. I'll say up front that I know I'm setting myself up for a ribbing, but here goes. The Instructions say ...DO NOT Close Bond. I'm hoping someone might be able to explain what close bonding is so I make sure I do not do it.
Okay, let the ribbing begin. Hahaha
But if anyone can get serious I'd really like a straight answer.
Here are a couple pictures of the instructions. Clicking on the pics should make them plenty big enough to read.
https://photos.app.goo.gl/Qzo2ZpSC2gkQGeP57
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 12-16-2018, 04:32 PM   #2
Re-Pete's Avatar
1992 29' Excella
Crap, I finally read it correctly. Oh well it's out there now. Hahaha
Pete
Virginia Beach, VA
Old 12-16-2018, 04:32 PM   #3
Kensington , Maryland
(Actual serious response follows...)
That means you will apply the 3M adhesive to both surfaces than allow each to flash dry. Once both are dry you can "bond" them together eg. "mate" the two 3M doused surfaces. Get it?
This is process is a pretty standard method for gluing/bonding two surfaces with adhesive.
OK, now let the hilarity ensue
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 12-16-2018, 04:35 PM   #4
Re-Pete's Avatar
1992 29' Excella
Greetings Too Tall,
Yup, I was about a click ahead of you. Hahaha. Sometimes I really wonder about myself.
Pete
Virginia Beach, VA
Old 12-16-2018, 06:14 PM   #5
Originally Posted by Re-Pete View Post
Greetings Too Tall,
Trust me, you are not alone. There but for the grace of g-d.....
Old 12-17-2018, 02:17 PM   #6
2017 22' Sport
connelly springs , North Carolina
CDon't close bond
The adhesive is one of many forms of contact cement.....they all work the same, some better then others. Their use is not limited to the installation of gaskets.
rustyoldman is offline   Reply With Quote
Window weather strip adhesive? S.Chance Windows & Screens 7 04-21-2014 12:43 PM
Exterior strip coming off - suggestions for adhesive? loislane General Repair Forum 8 03-21-2012 07:31 PM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
To strip or not to strip. That is the question. mjmcwhorte Cabinets, Counter Tops & Furnishings 2 01-16-2006 08:10 AM
Window weather strip for Traveler body CindyH Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 05-06-2004 08:22 AM
