Old 04-19-2020, 06:04 PM   #1
1993 34' Excella
Barry's Bay , ON
Unhappy Acetic acid in silicone sealant damage?
Iíve found a couple new leaks in our airstream where the old sealant has given away. Iíve also read that silicone sealants that contain acetic acid can cause some damage to aluminum, at least etching it somehow for a stronger grip.
But it turns out all I have is silicone sealant with acetic acid in it and I may not be able to get anything else anytime soon.
Has anyone witnessed damage done by this type of sealant or is it just a huge pain to take off when the time comes?
Iím trying to weigh the pros and cons of water damage during the spring rains weíre getting in Ontario vs what acetic acid may or may not do.
LiamG is offline   Reply With Quote
Old 04-19-2020, 06:19 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Damage...yes.
HD packaging tape or Gorilla tape until the weather improves.
Tip...leave a corner folded under to gain purchase when you need to remove.🤔
Brakleen works well to get the sticky off.
Obrigado, ť hora de descansar.
Tahawus
Old 04-19-2020, 06:34 PM   #3
2017 27' International
Lake Havasu City , Arizona
I wouldn't use silicone on any exterior seam. Not only doesn't it hold up well outdoors, but when it fails, it's almost impossible to remove completely, and--here's the killer--nothing will stick to a silicone-contaminated surface... not even silicone itself. You have to grind down to the bare metal before you can re-seal.
(Ironically, Airstream appears to have used silicone sealant extensively on my 2017 International 27FB. Makes me cringe when I think about it.)
As for the acetic acid question, I'm reminded of something that happened to me back in the Seventies. My car's left outside rear view mirror was knocked by a passing car and the glass broken. I cut new glass to fit, and reinstalled it using black Permatex silicone sealant. It looked perfect, and I was proud of myself... for about three days. Then I noticed weird streaks in the mirror. They got worse and worse over the next week. The acetic acid vapor from the sealant had eaten the silvering right off the glass! The mirror was ruined, and I had to do the job over using a different sealant.
I second Bob's advice: cover the leaks with tape until you can get a non-silicone sealant. I recommend 3M no-residue duct tape. Many large hardware stores (Home Depot and the like) carry it.
Paprika is offline   Reply With Quote
Old 04-19-2020, 06:46 PM   #4
Long Island , New York
FYI "silicone damage acetic acid" mentions on AirForums:
https://www.google.com/search?q=sili...&bih=728&dpr=2
FYI
OTRA15 is online now   Reply With Quote
Old 04-19-2020, 09:27 PM   #5
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I use an industrial product made by Bostik, called Simson ISR 70-03. It is avaulable in grey or white. This product is used as an adhesive sealant in bus manufacturing. I have used it for several years with very good results. I was shown this product by a industrial supplier in Winnipeg that also sells Tempro products. They suggested that this was a superior product to use in our application. It sell about $15 per tube.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-20-2020, 09:26 AM   #6
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Acetic acid damage is a real thing. It also applies to using silicone adhesives in electronics. You *do* want to use the right stuff.
uncle_bob is online now   Reply With Quote
Old 04-20-2020, 09:35 AM   #7
1976 31' Excella 500
Chappell Hill , Texas
I echo that. Never use silicone on your Airstream, inside or outside.
tbashin is offline   Reply With Quote
Old 04-20-2020, 09:45 AM   #8
2018 19' Flying Cloud
Eugene , Oregon
Does Sikaflex 221 have silicone in it? Can’t see it anywhere on the label.
tjwoods1 is offline   Reply With Quote
Old 04-20-2020, 09:48 AM   #9
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
silicone? NNN-OOOO never use it, never on you AS If you can't get to a store to buy the correct sealent I would do like Bob suggests as a temporary fix.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 04-20-2020, 09:53 AM   #10
2019 25' Flying Cloud
Greeneville , Tennessee
Contact Out-of-Doors Mart in Colfax, NC. They have what AS recommends we use. I ordered and resealed my 30' Excella.
jimfa440 is offline   Reply With Quote
Old 04-20-2020, 10:44 AM   #11
Tifton , Georgia
If the silicon smells like vinegar, it has acetic acid in it. The acetic acid is a curing agent for the silicon, which is why it sets up quickly.
Ford does not recommend using silicon with acetic acid on any of their vehicles with aluminum body parts (F-150, Superduty, etc).
In the past I was able to find a GE product, Silicon 2, which was acid free. But it isn't available at Lowe's in our area.
You might try looking for this product: Dow 737 neutral cure RTV sealant, which is acid free but will take longer to set up. I've used neutral cure RTV (no acetic acid) on several aluminum bodied Fords (screwing in tiedowns) and have not had an issue with corrosion from acid. The neutral silicon seals as well, if not better, than the silicon with acid and there is no real odor.
xyzabe is offline   Reply With Quote
Old 04-20-2020, 11:20 AM   #12
1996 25' Excella
Tillsonburg , Ontario
Sikaflex is, I believe, a urethane product and does not contain acetic acid. Check the label or search the MSDS on the web
JCW
JCWDCW is offline   Reply With Quote
Old 04-20-2020, 11:27 AM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Silicone is not a good sealer on Al with or without the acetic acid. It does not stick well. Order a sealant from Outdoors mart or Amazon. You will get it in a few days.
Old 04-20-2020, 11:48 AM   #14
1984 27' Sovereign
Kenosha , Wisconsin
Parbond. Available from Vintage trailer supply. Just fixed a major leak next to my door with it.
leif9016 is offline   Reply With Quote
Old 04-20-2020, 11:59 AM   #15
Something Shiny
Mosinee , Wisconsin
While duct tape is a fix-all, the downside is that it can be difficult to remove, leaving residue. An alternative is gaffers tape, which has most all of the properties of duct tape, but can be removed without fear of damaging the surface. It does cost a bit more, but is readily available on Amazon.
Mark & Gina
2017 International Serenity
160W Solar roof mount + 160W Zamp portable
ProPride hitch, 1400#
2018 Ford F250 Platinum 6.7L Diesel
Pongo is offline   Reply With Quote
Old 04-20-2020, 12:57 PM   #16
2019 23' Flying Cloud
Waterford , New York
You need it use the correct sealant on aluminum or you will cause Crevice corrosion. Google aluminum sealant and corrosion, there is a lot of good information out there. The wrong sealant will cause it to leak in the long run.
Larry1492 is offline   Reply With Quote
Old 04-20-2020, 01:16 PM   #17
1993 34' Excella
Barry's Bay , ON
FYI
Thanks for the link there. I've read through those threads but couldn't get a clear understanding of whether the acetic based silicone just causes future repair jobs to be much more difficult or actually does any lasting damage to the trailer.
Anyway, I'll be staying away from it at all costs now.
Old 04-20-2020, 01:19 PM   #18
1993 34' Excella
Barry's Bay , ON
I wish anything was readily available on Amazon right now. In Canada, they've stopped delivering anything they deem "non-essential" (which includes food somehow) and delivery estimates are currently at 6 weeks.
Old 04-20-2020, 02:54 PM   #19
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Talked to the folks in the technical department at GE and they confirm that Silicon 2, which is acid free does no harm to aluminum. That may explain why AS makes use of silicon in its latest models. But I would only use it if I can't get Sikaflex or the equivalent and I am in a bind.
2016 International Signature (Oyster/Ebony), Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap, Equalizer hitch
DIY Solar: 500W Renogy panels, AM Solar hardware, Blue Sky MPPT controller and monitor, 470ah (C20) Rolls battery bank.
Hermes is offline   Reply With Quote
Old 04-20-2020, 03:01 PM   #20
Ronald Witherspoon
1974 29' Ambassador
Shawnigan Lake , British Columbia
Send a message via Skype™ to RWitherspoon
Wax proved to be a good temporary fix
While camped in the northern Rockies in Canada in 1996, we had leaks in a couple of windows. I had high quality carnauba wax (Mothers) on hand so that completely stopped the leaks, water flows right over it. Be careful to only wax the sealant and its edges.
That was 20 years ago, I reapply every spring thinking I'm going to remove the old sealant some day.
I'm now thinking the kids are going to inherit it with a can of wax and instructions.
RWitherspoon is offline   Reply With Quote
Acid wash or no acid wash? alan.aliciac 1959-69 Tradewind 10 09-04-2015 10:12 PM
Sealant removal? (Tar, Silicone, Butyl, & other sealants) JJA Cleaning, Stripping & Polishing 13 06-15-2015 11:11 AM
Silicone or not to silicone Micheleairst Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-29-2013 02:37 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Silicone / No Silicone for Fantastic fan polarlyse Roof Vents, Skylights & Fans 17 09-01-2010 01:30 PM
