Old 04-21-2020, 04:45 AM   #21
1993 34' Excella
Barry's Bay , ON
Found something
We have pretty limited options in Canada at the best of times but the local hardware store has this rubber based sealant which is similar to parabond. Any thoughts on the Lexel brand?
https://www.homehardware.ca/en/148ml...lant/p/2034596
LiamG is offline   Reply With Quote
Old 04-21-2020, 04:47 AM   #22
1993 34' Excella
Barry's Bay , ON
Originally Posted by RWitherspoon View Post
While camped in the northern Rockies in Canada in 1996, we had leaks in a couple of windows. I had high quality carnauba wax (Mothers) on hand so that completely stopped the leaks, water flows right over it. Be careful to only wax the sealant and its edges.
That was 20 years ago, I reapply every spring thinking I'm going to remove the old sealant some day.
I'm now thinking the kids are going to inherit it with a can of wax and instructions.
Carnauba wax is a great idea. Now I wish I had been taking better care of my Expedition and had some around!
Old 04-21-2020, 04:55 AM   #23
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have been using Lexel instead of silicone for a few years, wherever I would use silicone. But, I never used silicone on the exterior.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-21-2020, 05:51 AM   #24
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I carry some butyl tape to temporarily fix a leak.
2019 Ford Expedition Platinum
Old 04-21-2020, 06:21 AM   #25
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
I’ve been using this on my Airstream and have been very happy with it.
It available at any hardware or home improvement store and comes in grey.
https://www.canadiantire.ca/en/pdp/l...-0641068p.html
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2022 Toyota 4Runner SR5
AldeanFan is offline   Reply With Quote
Old 04-24-2020, 04:06 PM   #26
1993 34' Excella
Barry's Bay , ON
When to redo seals
I’ve been using the Luxent and it’s messy but fairly easy to work with.
When do you normally replace sealant? I have some that’s cracking and falling apart that I’ll obviously replace but others that look old and dry yet aren’t in terrible shape and are vertical along the sides of windows (see photo). Would you redo them all?
Old 04-24-2020, 06:56 PM   #27
"Cloudsplitter"
I used Captain Tolley's Creeping Crack Cure
Used 2 to 3 applications around the windows...👍
Nice thing...It all but disappears into the crack.
Old 04-26-2020, 01:12 PM   #28
1993 34' Excella
Barry's Bay , ON
Looks great
That’s a fantastic looking product. Next time I’m south of the 49th, I’ll be sure to procure some. Hopefully the border opens soon to nonessential travel!
Old 04-26-2020, 04:22 PM   #29
"Cloudsplitter"
No real need to scrape the old stuff out...🤔
I wiped the cracked original sealant down with mineral spirits, and let each application dry,(it's clear dried). It will usually take several applications to finish.
Good Luck...
Acid wash or no acid wash? alan.aliciac 1959-69 Tradewind 10 09-04-2015 10:12 PM
Sealant removal? (Tar, Silicone, Butyl, & other sealants) JJA Cleaning, Stripping & Polishing 13 06-15-2015 11:11 AM
Silicone or not to silicone Micheleairst Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 07-29-2013 02:37 PM
Silicone tent seam sealant over rivet heads jayg Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 03-10-2011 10:25 AM
Silicone / No Silicone for Fantastic fan polarlyse Roof Vents, Skylights & Fans 17 09-01-2010 01:30 PM
