10-10-2020, 01:16 PM
1995 30' Excella
Harper Woods
, Michigan
about over-application of sealants & glues
Hello,
I'm dealing with a previously described leak of the Penguin air conditioner condensation/rain drain, at the connection between the drain pan and discharge hose connector. There was big glob of caulk smeared around and on the connector and drain pan, and yet water was infiltrating past it and dripping.
I noticed this before but haven't mentioned it, that sealants and glues seem to be more cohesive than adhesive, i.e. it sticks to itself better than the surface that needs to be sealed. As before, it appeared to me that that the solvent and plasticizers had gradually evaporated, and the caulk had shrunk and contracted, and pulled away from the surface. Considering that there is very little water pressure on this joint (an inch or two of water at most), a thick glob was unnecessary and just made things more difficult in the end. Proper surface preparation and a thin layer are all that's really needed.
So I cut and peeled the glob away and cleaned the surface. At the moment, the only sealant I have is Lexel (Sashco mfr), and so I applied a thin layer around the fitting and tiny cracks, and smoothed it over. I think it will work ok, considering that there is very low pressure, and if it doesn't, then it won't be difficult to remove it, and maybe try Captain Tolley's Creeping Crack Sealer. I'll let you know if the Lexel doesn't work.
10-10-2020, 01:32 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Good to know.
This would also be good to post in the sealants summary thread.
Hittenstiehl
10-10-2020, 01:39 PM
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee
, Georgia
Following
10-10-2020, 02:36 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Welcome Aboard 👍
I cleaned ALL the surface factory 'goop'. Re-sealed the mating curbs and screw threads and heads with 3m marine sealant, and covered with 3m Extreme Sealing tape.
10-10-2020, 04:04 PM
2017 20' Flying Cloud
Williamson County
I had a cargo trailer that developed a leak around the roof seam. It had a large amount of sealant extending away from the joints, but you could lift it in large pieces with no bond to the aluminum. So yes it is all about surface prep including a good primer perhaps.
2018 GMC Canyon CCSB V6 Mallet Supercharger
2006 Chevrolet CCSB 2500HD 6.6T LBZ
10-10-2020, 04:37 PM
Oswego
Less, (properly and carefully applied) is more....
-Rich-
10-11-2020, 10:49 AM
2005 31' Classic
Venice
Why not replace the hose ?
10-11-2020, 01:14 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Be careful using alcohol as a cleaner. Some sealants are incomparable with it. Carburetor cleaner is better.
guskmg
10-11-2020, 06:40 PM
1988 32' Excella
Robbinsville
, New Jersey
It's quite difficult to feed a new hose between the skins from the AC to the bottom of the trailer.
10-12-2020, 07:36 AM
2007 27' Safari FB SE
Waterloo
, Ontario
I had a similar leak and a similar gob of separated sealant. On closer inspection, I found the plastic itself had hairline cracks. I cleaned it well, checked that the plastic was dissolved by acetone (styrene) and used acetone to soften the crack areas a sacrificial piece of styrene to strengthen it. No caulking/ sealants. Ugly, but better (stronger) than new.
10-12-2020, 08:04 AM
2019 22' Sport
Bend
, Oregon
guskmg
Assuming one allows substantial time between cleaning and application of the new sealant, isn't it safe to assume the alcohol will have evaporated completely?
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Caulking and Sealants (silicone, parbond, vulkem & more)
Chuck |
Leaks - Weatherstrips, Gaskets, Caulks & Sealants |
266 |
07-01-2017 11:41 AM |
Sealant removal? (Tar, Silicone, Butyl, & other sealants)
JJA |
Cleaning, Stripping & Polishing |
13 |
06-15-2015 11:11 AM |
Answers to adhesive decal glues blues
AIR-Quarius |
0 |
08-25-2014 11:43 AM |
application temperature for vulkem
bhsl8 |
10 |
02-25-2007 09:35 AM |
Caulks & Sealants
Torii |
8 |
05-31-2005 12:14 PM |
