Old 03-23-2020, 06:11 PM   #1
V Pline's Avatar
1962 19' Globetrotter
DeWitt , Michigan
61 Overlander - can not locate leak by back window
WOW! We are digging into a leak by the back window. We thought we had it fixed - but after installing new flooring - we discovered water! So we are back to square one! Anyone have luck - finding leaks?! Ideas where to look? Any advice would be great!
V Pline is offline   Reply With Quote
Old 03-23-2020, 06:54 PM   #2
1966 22' Safari
Fredericksburg , Texas
Some resort to air pressure tests. Some RV repair places offer this. Also, I’ve known some who have used a blower (like leaf or squirrel cage) and brushed soapy water on the exterior. Potential leaks would blow bubbles due to forced air from the inside. They would fashion a piece of cardboard at an exterior opening and create a forced air entry point with the blower attached with tape. So, positive air pressure. Water can travel. The leak could be well above your window and traveling. Or, make sure all your rivets and seams are sealed with something like Parbond. Good luck
Bubba L is offline   Reply With Quote
Old 03-24-2020, 10:43 AM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I had a leak at my front window in my '61 Safari. I sealed every seam above the window on the end cap. No more leak. I then sealed the seams on the back end cap as a preventative measure. Going on 8 years ans no more leaks.
Sam
samb is offline   Reply With Quote
Old 03-29-2020, 09:30 PM   #4
KyBryanP
1978 31' Sovereign
Louisville , Alabama
Sam
Hey, what did you use to seal your seams and how did you apply it? Thanks in advance
KyBryanP is offline   Reply With Quote
Old 03-29-2020, 11:26 PM   #5
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
To seal my end cap seams.......... I first removed every bit of the original sealer I could, and as deep as I could. The original sealer was brittle and I was not gentle. I used an old metal "church key". That old fashioned can opener that made the triangular hole in the top of a beer can before pull-tab openers were invented. I raked the pointed end through the seam with a fair amount of pressure. I repeated the process five or six times on each seam until I could see no sign of old sealer. I am sure I even removed some aluminum, but when done each joint was clean shiny I then ran some tape on each side of the seam about 3/16ths of an inch apart with the space between centered on the seam. I used a small bead of grey vulkem smoothed and pressed into the joint with a finger. Then immediately removed the tape. The grey vulkem is hardly visible when finished.
Sam
Old 03-30-2020, 10:15 AM   #6
Paradise , Texas
Look for acryl-r. It's a much more invisible leak repair. It comes in a metal can with an oil can type dispenser. Especially if have polished, or will polish, it disappears much more nicely than a wide bread of vulkem or sikaflex.
Crackerman is offline   Reply With Quote
locate plumbing leak 1973 23' Patrick Lamb General Repair Forum 3 05-13-2014 04:51 PM
Can't locate fresh water tank drain valve - 1974 27' Overlander International Razorhog Fresh Water Systems 11 04-22-2014 09:14 PM
1965 26' overlander - where can i locate rear tail light housings/bases groovzilla Lights - Interior & Exterior 1 12-28-2013 11:28 AM
Can't locate low point drain values MR AIRSTREAM Winterizing, Storage, Carports & Covers 0 09-15-2011 08:57 AM
can't locate six position switch on my 345 johnboy28540 Generators & Solar Power 4 03-13-2009 05:26 PM
