Old 07-04-2019, 12:25 PM   #1
2018 27' Globetrotter
Vancouver Island , British Columbia
Skylight sealant
I have two skylights that I’m trying to reseal. I don’t see any screws to remove them. My question is how do you maintain them ?
In this case should I add just dicor ?
Please see photo Click image for larger version
rintintin is offline   Reply With Quote
Old 07-04-2019, 07:52 PM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
What year? Factory skylights or add-ons. This doesn't look like the installation on my 2012, which was glued on only, on a raised berm on the roof. Are you sure your leak is coming from the skylight? Or migrating from the antenna or other roof structure.
I replaced mine with a Maxim Skylight and redid the fans and antenna too.
Old 07-04-2019, 08:53 PM   #3
I don’t have a leak but I’m just doing maintenance. I bought the unit used. 2015 flying clouds ( 30 feet)
Old 07-04-2019, 08:57 PM   #4
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
2014 23' International
Dadeville , Alabama
If I whereyou I would replace it with a new maxim skylight before it becomes a problem.
Here’s a link to my blog post.
http://www.airforums.com/forums/blog...skylight-3003/
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 07-05-2019, 12:31 PM   #5
2019 25' Flying Cloud
Hendersonville , North Carolina
Skylight sealing
I second GMFL on Maxim replacement. You only have to do it once. Quality product.
Probably not a good idea to inject a bunch of sealant at the base of current plastic skylight and the skin of the Airstream roof. The plastic lid is held onto the base by double sided tape. If you try to remove the plastic dome lid it will break up.
When the time comes for the plastic dome lid to be replaced, get a Maxim.
uraljohn is offline   Reply With Quote
Old 07-05-2019, 12:38 PM   #6
A W Warn's Avatar
rural , North Carolina
I also recommend the Maxim replacement. I replaced mind about 5 years ago.
Short term, removing the caulk at the base and re-caulk will not hurt anything. But, might trap condensation if any gets in there. No need to remove the skylight.
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 07-05-2019, 01:19 PM   #7
Thanks I will do that. Is that a complicated job? From what I can see I just have to pop out that old skylight
Old 07-05-2019, 01:21 PM   #8
Thanks for the info. I’ll remove the caulk and re-caulk it until I come back from wintering in California.
Old 07-05-2019, 06:02 PM   #9
A W Warn's Avatar
This thread has been going on for years. Step by step instructions.
http://www.airforums.com/forums/f455...hts-53517.html
Look up Maxim and give them a call. They know exactly what you need, you just need to confirm dimensions and select lens color.
ps:
Those original skylights can get brittle and fly off going down the road. (your 2015 should have a few years left) I've had that happen far from home on a rainy day. If you happen to loose the skylight on the road somewhere you can get a flat sheet of Lexan or Plexiglass for a temporary cover at almost any hardware. Some hardware stores will cut to fit.
Alan
skylight gasket, velcro residue on skylight glass basecamper Base Camp 0 06-11-2016 09:52 AM
Sealant for roof vents & skylight? Dodge Man Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-31-2013 06:43 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Double seals on skylight? TomW Roof Vents, Skylights & Fans 1 03-01-2004 08:44 AM
Skylight - WARNING - possible Problem apple 1 Roof Vents, Skylights & Fans 0 03-24-2002 09:16 AM
