Old 03-03-2020, 08:26 AM   #1
2018 19' Flying Cloud
Eugene , Oregon
Reverse Flow Fantastic Fan?
I have two Fantastic Fan models with rain sensors on my 2018 Flying Cloud 19í. I have seen some Fantastic Fans that allow one to reverse the flow of air. (My Airstream is in storage at the moment so I canít check it). Is this feature standard on my installed Airstream fans or would I have to upgrade / install to a different model ?
tjwoods1 is offline   Reply With Quote
Old 03-03-2020, 08:30 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If your fan has that feature, it would have a large rocker switch that has 3 positions. IN - OFF - OUT
Richard
azflycaster is online now   Reply With Quote
Old 03-03-2020, 09:04 AM   #3
2007 22' International CCD
It is possible to add a reversible switch to existing FantasticFans yourself. Search the forums for the method and parts needed.
rmkrum is online now   Reply With Quote
Old 03-03-2020, 09:32 AM   #4
2020 25' Flying Cloud
Atlanta , Georgia
I'm pretty sure that our colleague Rocinante did a video on reversing the flow. I don't think it was switchable, it was a permanent "in" flow. But for those of us with two hatches, that's a pretty useful deal. You might contact Rocinante or look at their great website ... he's a pretty good guy and they give great advice.
Belbein is offline   Reply With Quote
Old 03-03-2020, 09:40 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Originally Posted by tjwoods1 View Post
I have two Fantastic Fan models with rain sensors on my 2018 Flying Cloud 19’. I have seen some Fantastic Fans that allow one to reverse the flow of air. (My Airstream is in storage at the moment so I can’t check it). Is this feature standard on my installed Airstream fans or would I have to upgrade / install to a different model ?
According to the parts manual for your trailer there is no reverse. It says "exhaust only" on page IV-72.
https://www.airstream.com/wp-content...Parts-Book.pdf
It is not hard to add a switch that will allow the fan to reverse. Plenty of youtube videos show how to DIY cheap.
And Fantastic has an upgrade kit that is plug and play.
https://www.amazon.com/Fan-Tastic-Ve.../dp/B00IKMBXY2
Alan
Old 03-03-2020, 11:25 AM   #6
Kensington , Maryland
Call them. I've seen (here) that they can supply a kit to add this feature.
Infact, google says >> https://www.campingworld.com/fan-tas...ite-56327.html
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 03-03-2020, 01:37 PM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Not a believer in one in and one out anyway. The hot air is at the ceiling. 2 blowing out has to be better. Plenty makeup air comes in through the window and doors. I have fans with the reversing feature but have not used it except to try it to see if it worked. If it gets hot enough I probably will have the AC on instead.
Old 03-04-2020, 10:00 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
We have this on our 2004 Int'l 25 however, like Bill M. we run both out only with windows open there is MUCH better circulation.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 03-04-2020, 10:43 AM   #9
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
The easy way...
Open BOTH vents
Close ALL windows including shower and bathroom vents
Turn ON one fan!
Viola!
You have one vent pulling in the air while the vent with the fan ON will pull air out.
"No job is so simple that it cannot be done wrong."
"Everyone is entitled to be stupid, but some abuse the privilege."
"Either I will find a way, or I will make one."
WBCCI 9164
cazual6 is offline   Reply With Quote
Old 03-04-2020, 02:25 PM   #10
CruizinDux's Avatar
Tracktown USA , Oregon
Hi Tom, I'm with Bill and drbrick. Our OEM's (2014) were one way but were replaced under (parts only) warranty by FV in 2017 & 2019. The base flanges had cracked and I was seeing some moisture inside.
The new fans (3350) they sent came with the Fwd/Rev switch. Another benefit I discovered was the fan blade assembly was more easily removed from the inside for cleaning of the rotor and/or the inside of the dome.
Not to digress...my experience is that while 2 fans (on high) and on exhale certainly clears the cabin, I found it to be noisier. Now I exhale the Fwd fan above the dinette, rung it on #1...maybe 2, and cracking my dinette window (with shade down) and sometime the rear sink window (again shade down) , even just a couple of inches (before the first stop) was more efficient and certainly quieter. I prop them open with small sections of foam pipe insulation, so if the blow away, no big deal.
The only time I use the push/pull method is when I'm parked while OTR and the dog is inside. At those times I feel more comfortable keeping the vents open vs opening a window on an unattended TT.
Happy Trails,
CruizinDux is online now   Reply With Quote
Old 03-04-2020, 02:44 PM   #11
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Another reason to use one fan blowing in, one fan blowing out ->
When one or both fans are blowing outward negative pressure is created (suction pulling air inside from outside). If the toilet is flushed while the fans are running air will be sucked in through the black tank vent through the tank and through the toilet. THATSTINKS!
If one fan is blowing inward on a slightly higher speed than the one blowing outward the interior is pressurized so that no smell comes in when the toilet is flushed.
Alan
Old 03-04-2020, 03:53 PM   #12
Bingo!
Thatís not a fun experience...
Old 03-04-2020, 04:56 PM   #13
CruizinDux's Avatar
maybe this is where covering the toilet with plastic comes into play... post #34
https://www.airforums.com/forums/f45...-205907-2.html
p.s. just for the sake of discussion, would not the bath fan accomplish the same thing? I guess at least it would exit the bathroom ceiling.
Old 03-04-2020, 05:04 PM   #14
Steamguy's Avatar
2019 27' International
Washougal , Washington
One thing that having the fan reversible does, especially for AS owners:
Put the fan on INTAKE, close and seal all windows and doors, then go outside and start squirting seams with a dilute dish soap solution. Instant leak detection!!
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 03-04-2020, 05:52 PM   #15
1996 25' Excella
Tillsonburg , Ontario
Pretty sure you will find that with the Rain Sensor you also have reversing switch
Both of mine do...one with rain sensor the other without!
JCW
JCWDCW is offline   Reply With Quote
Old 03-04-2020, 05:57 PM   #16
2016 30' Classic
Houston , Texas
Good idea!
dhroberts is offline   Reply With Quote
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Fantastic Fan with Reverse Feature gandttimes General Repair Forum 59 04-12-2015 11:42 PM
Fantastic Fan Reverse Flow Switch 2dabeach 2007 Safari SE 5 10-08-2014 03:54 PM
Fantastic fan does not work in reverse djpierce Roof Vents, Skylights & Fans 18 09-24-2013 02:27 AM
reverse switch on Fantastic Vent bradk Roof Vents, Skylights & Fans 19 07-12-2006 11:11 PM
