Old 02-28-2022, 08:54 AM   #1
1995 30' Excella
Harper Woods , Michigan
Replace a fantastic Fan cover with only a "Ultra Breeze Cover" by Fantastic Vent?
Hello,
A couple of months ago, a severe windgust broke off the cover of my Fantastic Fan on '94 Excella. It was a heck of a blow, as it also snapped a 100' maple in my yard, at 30' off the ground. Since the weather at that time was so inclement, I temporarily covered the hole, and so now it's time to repair the damage.
Would it be feasible to skip replacing the cover dome and just install a "Ultra Breeze Cover" manufactter by Fantastic? On the inside, I would make an insulation panel that would be held on by Velcro strips. Would the Utrabreeze cover be stormproof, considering that the exterior vent flange would still be in place to divert water from the opening?
Bob Blarney is offline   Reply With Quote
Old 02-28-2022, 10:03 AM   #2
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Doesn't seem like a good idea to skip replacing the Fantastic Fan's dome cover, regardless of whether or not you install the Ultrabreese. There would be no good way to keep the outside out, including dust, bugs, heat, rain, etc. Even with the Ultrabreeze you'll have issues, IMO.
Might be a good time to consider installing a MaxxAir Deluxe which can operate without the need for an external secondary cover.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 02-28-2022, 10:17 AM   #3
1995 30' Excella
Thanks for the reply.
Aside from the fact that the work and expense of replacing the entire fan wouldn't be much fun, the existing fan works perfectly with 3 speeds, reverse, thermostat, rain sensor, and it has a bug screen on the inside. And I think it wouldn't be difficult to install a bug on the Ultrabreeze cover. I think it might be time to go look at one in person, to see how well built it is, and how stormproof it might be.
Old 02-28-2022, 10:31 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I would replace the missing cover and while you are on the roof, add the exterior vent cover.
Richard
Old 02-28-2022, 02:32 PM   #5
1995 30' Excella
the PO was thinking ahead
Well, I went rummaging around and found a spare dome cover in one of the dinette seat compartments. It doesn't have a hinge on it, but I can probably use the existing hinge. Now, I'll just wait for a warm day.
Old 03-01-2022, 10:03 AM   #6
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Smart move. I have two Fantastic Vent fans and both are covered by Fantastic Vent covers. I can assure you that rainwater can still get in if wind is driving it in the right direction. In a heavy rain my vents both close even with the covers.
Old 03-02-2022, 07:32 PM   #7
1995 30' Excella
Considering the storm that tore off the original cover, the operable dome is essential, and the other cover is a real convenience. By the way, the windstorm wasn't also with rain. The trailer door was open because I was tidying up, and the wind pressure through the open door might have had something to do with the event.
Ultra Breeze Fan Cover doesn't fit 16' Sport? Ghome Roof Vents, Skylights & Fans 0 02-01-2021 12:18 PM
Fantastic Fan Cover "Ultra Breeze" - Questions PatLee On The Road... 3 07-15-2019 10:57 AM
Sealant for install of Fantastic Fan Ultra Breeze SilverHouseDreams Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 09-28-2017 07:45 AM
Fantastic Ultra-Breeze or Maxxair II? TinTin Roof Vents, Skylights & Fans 2 11-08-2014 08:59 AM
