Originally Posted by SuperTrouper
A word of caution from a Maxxair fan (pun intended), While I love my Maxxairs for all the reasons mentioned previously, the electronics in them do not like more than 13.5 volts. This is a known weakness. As I have lithium batteries my system sometimes delivers 14.5 volts to top off the batteries. i ended up replacing the control boards on my MaxxAir fans as they failed and added a small Victron 12-12VDC regulator on the fan circuit to hold it at 12.8 VDC to protect the fan electronics. If you have regular lead acid batteries you should be fine.
Might be good to check with MaxxAir on this...I seem to remember that they updated the circuitry to correct this issue.
