Old 06-29-2018, 10:49 AM   #1
1995 30' Excella
Harper Woods , Michigan
quick & effective skylight insulation insert
Hello, it's unusually hot in Michigan - 95F +, and so I made a quick sunblocker panel for the skylight, which I'll redo and make a permanent accessory.
I cut a piece of rigid EPS house insulation to fit into the skylight ceiling frame, with a 1/4" allowance on all sides for self-adhesive multi-rib weather stripping around the perimeter (I should have allowed 5/16"). The friction holds the panel in place quite nicely.
I"l redo it with a bit more care when I get the time, and paint it white to match the ceiling. But for now, it's doing what is needed.
Bob Blarney is offline   Reply With Quote
Old 06-29-2018, 11:54 AM   #2
1995 30' Excella
It seems to work. I poked a thermometer through the EPS - it's 155F above the EPS, and 83F below it. Hmm, is there a potential problem with trapping that heat above the foam / below the plastic glazing?
Skylight insulation Mollysdad Roof Vents, Skylights & Fans 8 08-02-2023 05:26 PM
skylight gasket, velcro residue on skylight glass basecamper Base Camp 0 06-11-2016 09:52 AM
1967 Caravel tongue jack & table insert. kda1 Airstream Classifieds 0 03-04-2015 04:52 AM
Low Cost Effective Anti Theft For As!! KIMILI Insurance & Claims 12 11-13-2003 11:41 AM
