SO i installed my natures head composting toilet and needed power for the fan. I figured there was plenty of
12v around just needed to find it. I pulled the cover off the fan switch on wall and started looking around with a light probe i grounded on the LP copper line under cabinet.
I found power on the up/ down hood switch and then started looking for a negative side. On the fan switch there was a white wire so I hooked my clamp to that and got light.. OK great power for my fan.
I cut the butt connector off, rewired adn attached small wire for plug for NH fan and plugged it in and EURAKA.. fan worked.. so i start to push everything back in wall to screw cover back on and checked fan and NOTHING.. same with lid up down.
I have tried EVERYTHING, plus a lot of very colorful words, and can not figure ouit what the hell happened.. I really only took off butt splices and did check the connection and it appears OK.
I have attached a couple of picture of the switches..
any help appreciated
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691,
Piedmont Airstream Club, Unit #161, Region #3
