Old 07-18-2021, 07:57 AM   #1
2018 30' Classic
Lake Charles , SW Louisiana
Loss signal: Firefly to Fantastic Fan - Seeking Troubleshooting Clues!
For whatever reason our Firefly Panel is no longer recognizing our forward LR fantastic fan. The icons on the Firefly panel will not. illuminate, i.e. either manual or auto modes and pressing of the control buttons to open/close the fan or turn it on/off is working.
I can bypass the Firefly and go direct to the fan and it has power but again, there is a disconnect somewhere.
Seeking suggestions.
2018 Classic M30 RQB
"Finding the Roads that Await Us!"
Rick & Lydia Williams
rewillia is offline   Reply With Quote
Old 07-24-2021, 12:31 PM   #2
2018 30' Classic
For whatever reason our Firefly Panel is no longer recognizing our forward LR fantastic fan. The icons on the Firefly panel will not illuminate, i.e. either manual or auto modes and pressing of the control buttons to open/close the fan or turn it on/off is not working.
Old 07-24-2021, 01:19 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
There's a cable that plugs into the fan. It runs to a wiring harness. That harness hooks to the Firefly controller. First thing is to trace that cable from the fan down to the controller under the wardrobe. Make sure everything is tight.
Once you are sure everything is plugged in. the time honored approach on all modern tech is to reboot it. In this case, go off shore power and disconnect the battery. Wait 60 seconds and then hook it back up. That may or may not help.
The cable plugs into a control board in the controller. If that board dies then the fan is offline. Troubleshooting / replacing that board is going to mean a call to JC or to Firefly. There isn't a lot you can do to fix it yourself.
Old 07-25-2021, 09:51 AM   #4
2018 30' Classic
Hi
Bob, I've traced it to both the 70038A Firefly Vent Fan controller module which is in the ceiling next to the overhead fantastic fan as well as to the back of the G6A DC panel 7100003AC and found all the can terminals to be tight. I m now suspect that the 70038A vent. fan controller is bad and have since ordered one from Firefly. Cutting all power and rebooting did not change anything.
Thanks for the valued input.
Rick
Old 07-25-2021, 09:56 AM   #5
Half a Rivet Short
Rick
Hi
It's only valued input *if* it fixes the problem, until the fan is actually working, it's just another scatter brained idea
Indeed there are tests you can run on a CAN bus with the right gear. I suspect there is a Firefly training module on how to do that. Good luck getting at it as a random customer. Their customer service might be able to get you a link if you have a bunch of test gear.
Intermittent loss of communication between Firefly Multiplex Control Panel and Alde rewillia General Repair Forum 3 12-04-2020 03:22 AM
Furnace On The Fritz Again! More Clues! Help!! Rounder44 Full-Timing, Winter Living & Workamping 6 12-30-2018 12:04 PM
Tv signal loss when charging ipad cbrittan Electrical - Systems, Generators, Batteries & Solar 28 08-16-2016 03:02 PM
TPS repeater location due to loss of signal? carver 1 2011 - 2015 Classic (all lengths) 6 03-31-2015 05:48 AM
troubleshooting fantastic fan that stopped running bonginator Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-05-2014 03:42 PM
