Old 09-21-2020, 08:08 PM   #1
2018 23' Flying Cloud
Park City , Utah
Fantastic fan vent won't open
I see a couple of other threads about fantastic fan issues, but this is slightly different. In my case, the vent won't open when I flip the switch, but it will open manually with the crank. The fan won't turn on once the vent is open.
I think I may have unintentionally driven home from a long trip with this vent partially open.
Anything I can do to troubleshoot or fix myself?
switters is offline   Reply With Quote
Old 09-21-2020, 08:52 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Check the fuse
CRH is offline   Reply With Quote
Old 09-22-2020, 06:44 AM   #3
Park City , Utah
Originally Posted by CRH View Post
Check the fuse
Thanks. I looked at the fuse listing and it appears that the reading lights over the bed and a few other things are on that same fuse, and those are still working. I assumed that meant the fuse isn't the issue?
Old 09-22-2020, 07:48 AM   #4
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Is the fan speed set at 1, at the minimum?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-22-2020, 08:01 AM   #5
Park City , Utah
Pat
Yes.
Old 09-22-2020, 08:07 AM   #6
"Cloudsplitter"
Wind it up manually, lock the handle, turn off the rocker switch, see if it closes. It may be the limit switch.
Old 09-22-2020, 08:35 AM   #7
Park City , Utah
I'll try that. If it is the limit switch, what then?
Old 09-22-2020, 09:09 AM   #8
Park City , Utah
Never mind! I figured out what was going on. The fuse on the fan was still operational. However, I pulled the entire fuse case down to expose the wires, and found that one of the wires the fuse connects to had become dislodged. When I pushed it back in, the fan started working again.
Old 09-22-2020, 09:25 AM   #9
Spaggs's Avatar
2022 28' Flying Cloud
GAINESVILLE , GA
Awesome! I hope corporate is reading this and will adjust. Wire connections should stay put.
Spaggs is offline   Reply With Quote
Old 09-22-2020, 09:55 AM   #10
2021 23' Globetrotter
Jefferson City , Missouri
Rain Sensor
Glad you solved the mystery. I ran into a similar issue this summer while camping - just would not open or run. It was scheduled for a warranty check the next week. I added it to the list - the tech told me that a heavy dew will trigger the rain sensor. After the tow to the dealer on a sunny day it worked just fine.
Jsailmo is offline   Reply With Quote
Old 09-22-2020, 09:56 AM   #11
1949 22' Liner
Cincinnati , Ohio
Agreed. One of my two Fantastic Vents wouldn't work when I first wired it up. I opened it up and discovered one of the wires to the plunger switch was loose.
Reattaching it with wire glue resolved the problem, but I shouldn't have had to. Admittedly, that vent had sat in a box in the basement for a decade before I installed it, but still.
TheOhioSean is offline   Reply With Quote
fan vent cover won't open Bob Schrader Base Camp 1 06-24-2020 10:03 AM
Repair - Fantastic Vent Won't Open Al and Missy Roof Vents, Skylights & Fans 1 07-17-2019 04:30 PM
Fantastic Fan Cover Stuck - Won't Open time2play Roof Vents, Skylights & Fans 3 04-20-2016 10:48 PM
Fantastic Fan Open During Travel chaseav 2011 - 2015 International 27 05-28-2015 12:55 PM
Fantastic fan vent- manual open 3 speed MCADELS Airstream Classifieds 0 07-08-2014 04:32 AM
