Old 04-13-2020, 04:08 PM   #1
2011 20' Flying Cloud
Orlando , Florida
Fantastic Fan power oscillation
On 12v and 110v the fan motor continually oscillates slightly on/off by itself. This causes the motor to continue running when the vent is all the way up or down. The resistor speed switch was swapped out and the exterior rain sensor was replaced with no change. Voltage at the switch jumps around from 1 to 110 volts. Any suggestions without replacing the fan unit is greatly appreciated.
2011Cloud is offline   Reply With Quote
Old 04-13-2020, 05:05 PM   #2
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
The unit should never see 110 volts !
You have an electrical problem in the trailer !
It could be a floating ground or intermittent converter problem.
Get it checked out by a pro.
There could be a shock hazard on 110v if you’re standing outside and touch the trailer skin .
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 04-22-2020, 03:26 PM   #3
Orlando , Florida
Voltage continually strays from 1 V to 110 mV. Should have checked my post sooner. Thanks for responding.
Any suggestions whether this is a full unit replacement issue or possibly a motor swap.
Old 04-22-2020, 04:30 PM   #4
2008 22' Safari
IT DOESN’T sound like a “fan problem”... it sounds as if it’s a wiring problem,...perhaps a dangerous one. Fix the WIRING and the fan will likely work properly.
Fantastic Fan, Dining Room Lights and Bath Fan not working Arbi Electrical - Systems, Generators, Batteries & Solar 21 07-10-2020 05:25 PM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
