Old 01-16-2017, 10:30 AM   #1
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
Fantastic Fan not working - red LED
I have single Fantastic fan in my 2015 27FB International. The cover will motor up and down but the fan will not start when switched on. I have adjusted the temp setting up and down still no luck.
Reading some posts a quick call to the customer service dept and they suggested to clean the ground switch on the top under the cover that I guess turns the fan off as the cover closes.
I will try this tonight. Any other suggestions? I could not find a manual online with the meaning of the LED on.
Thanks.
Boundless Power Systems LLC
Mount Vernon, OH
27FB International / Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 01-16-2017, 10:55 AM   #2
Lily&Me's Avatar
Normal , Illinois
I had this exact same problem last summer, stopped and had someone get on the roof to check the wiring, which had come loose.
He tightened it, and it has worked fine since.
Good luck.
Maggie
🚐 Interstate Owner Emeritus 🚐
🌹 Cherish and appreciate those you love. This moment could be your last. 🐚
Fantastic Fan - Rain Sensor Not Working jbroedlow Roof Vents, Skylights & Fans 6 05-15-2016 03:43 PM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Fantastic Vent - fan not working 05ModPod Roof Vents, Skylights & Fans 20 12-14-2014 04:52 PM
Red! Red! Red! Can Anyone Tell Me What This is About Now? Fly at Night Batteries, Univolts, Converters & Inverters 23 11-06-2011 01:18 PM
