Old 04-07-2020, 01:06 PM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Fantastic Fan Motor Replacement
My '86 Sovereign 25' was purchased used and had Fantastic Fans installed at an Airstream rally according to the previous owner. Both can motors had dates of '02. Bearings went out in one and it was replaced with a RSTA6000 motor dated 4/12. These had a fan blade assembly pressed onto the shaft. I had another one with bearing failure so I ordered a replacement from what is now Attwood after they aquired Fantastic Fan. What I got was a fan assembly smaller in diameter held onto the shaft with a screw and a pancake motor. A combination of smaller dia. and what I feel is a weaker motor was poor performance. After 6 months the motor started squeaking so I pulled it out and replaced it with the can motor I took out. If I'm going to have squeaking then it had better come with plenty of airflow. Bearing are getting worse and amperage usage has increased on lower speed.
I have no plans to order any pancake motor model from Attwood ever again so I am looking for a replacement motor, the larger fanblade assembly complete with bowtie mounting bracket. Does anyone know where I might locate one new or used or if there is a source for a replacement motor? Any help would be appreciated.
Old 04-07-2020, 02:43 PM   #2
Paradise , Texas
Unfortunately dometic hasnt done fantastic fans any favors.
Step up to Maxx fans. More speeds, better blades, quieter operation, you really can't go wrong with the investment.
Crackerman is offline   Reply With Quote
Old 04-07-2020, 03:58 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
As Crakerman said, don't waste your time and money on the FF!! Buy a Maxx air and solve your problems. Better speeds, quieter, and FAR better service!! Speaking from experience with both brands!
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-08-2020, 12:17 PM   #4
davidz71's Avatar
1986 25' Sovereign
Thanks guys. I knew that would be what I would probably have to do but I hated to have to remove the FF after resealing it a couple years ago.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-25-2021, 07:53 PM   #5
davidz71's Avatar
1986 25' Sovereign
Update:. Never did find a replacement motor but I know there has to be one out there. Since the commutator and brushes are near the top of the motor and I felt that it was the lower bearing giving me trouble, I sprayed Fluid Film into the lower area of the motor and it made its way into the bearings. I have used this stuff on all kinds of equipment since learning about it from a friend. It sprays like a liquid and sets up like a light grease. The fan is quiet now so on to other projects.
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
