Fantastic Fan lift knob 'popping out of gear'
Problem I have found now is that with the sale of Fantastic Fan to Atwood, the parts supply is not always reliable. Reliable means while you may be able to find a specific part, the part may not mesh with the older parts on the fan. I've found that the lift lever on my two fans has a pin which holds the other lever in place and both levers hinge together on this pin. The lever connects directly to a spline gear on the motor. I called Atwood and they gave me a part number and you end up having to purchase that through Amazon. Atwood doesn't sell it directly. Fast forward I get the new lever and find that connector that connects to the spline gear is smaller than the existing spline on the motor. I call back Atwood and tell them the problem. The support person says well of course it won't fit. You need to buy a new motor that has the proper sized spline that will fit that new lift lever assembly you bought. So I'm given a part number and I again have to purchase it through Amazon. Yes it fits. Bottom line rather than tear it all apart again I place a wire tie through that connection point in the two rods that holds them together. What I'm going to do is get a small cotter key and use that as the replacement for the pin. I'll keep the motor and lift rods for the day when the motor dies.
Bottom line be aware that replacement parts you obtain for the older fans may not be perfectly compatible with the parts they may need to mate with, which will possibly force to you buy other parts to return your fan to functionality. And to make matters worse Atwood may not make or stock the parts you need and will point you to third party Amazon's sellers for those parts.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
