Old 04-19-2018, 01:21 PM   #1
1972 29' Ambassador
saint louis , Missouri
fantastic fan gasket
my fans came with a foam gasket. use it and caulk after install? or pitch it and use butyl?
trashbag is offline   Reply With Quote
Old 04-19-2018, 02:51 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Pitch it. After a while it loses elasticity and will leak.
Al
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 04-19-2018, 02:51 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I did not use the gasket. I used a high quality polyurethane sealant and it has not ever leaked. I did however mount it on a totally flat surface.
Old 04-19-2018, 03:12 PM   #4
CRH
1995 25' Excella
xxxxx , xxxxxx
I used butyl and Dicor self leveling sealant on the outside edge and screw heads.
CRH is offline   Reply With Quote
Old 07-22-2020, 06:30 PM   #5
2004 19' International CCD
Ventura , California
What Size Butyl tape for Fantastic fan
So the Butyl tape replaces the old black gasket around the Fantastic fan? I'm assuming the Butyl tape should be the same size of the gasket?
Thank you
Laurie-
DoggerStream is offline   Reply With Quote
Old 07-22-2020, 09:10 PM   #6
CRH
1995 25' Excella
xxxxx , xxxxxx
I put the butyl tape between the fans plastic frame and the roof. It replaces the gasket.
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Fantastic Fan Gasket Use? SilverHoot Roof Vents, Skylights & Fans 13 07-27-2010 07:16 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
