Old 09-08-2021, 02:23 PM   #1
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Fantastic Fan fuse
Our Fantastic fan fuse blew, it is 4 AMP/125 VOLT, I am unable to find a replacement locally. The closet that I could find was 4 AMP/250 VOLT, since the fan is 12 volt can I use this one?
Gary
Castaway is offline   Reply With Quote
Old 09-08-2021, 03:06 PM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yup. A 4 amp fuse will blow at 4 amps, no matter the voltage.
Your fan is only running on 12 volts anyway.
2019 Ford Expedition Platinum
Old 09-09-2021, 02:12 AM   #3
2007 22' International CCD
The main difference between a 125 volt fuse and a 250 volt fuse is the 250 volt fuse body is stronger to prevent the body from shattering when the fuse blows, and there is ‘stuff’ in them to quench a higher voltage arc.
They blow at the same current…which won’t be absolutely exact. They are not that precise. The amp rating is that most of them blow aut at currents around their rating.
Old 09-04-2023, 10:32 AM   #4
2020 25' Globetrotter
Heidelberg , Ontario
our 2020 25-foot globetrotter dometic ceiling fans keeps blowing fuses
rvtravel1963 is offline   Reply With Quote
Fantastic Fan Fuse? StreaminGeo Roof Vents, Skylights & Fans 6 02-04-2024 11:23 AM
How to install Fantastic fan fuse holder Pride&Joy General Repair Forum 0 08-13-2017 06:43 AM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
