Well...did it ever work correctly?
Our Classic has the original FF. The newer units have changed a bit.
That being said the controls on our front fan can be a bit confusing.
Illustration...our fan has a speed switch that has a zero setting, nothing will work at all unless that switch is set on a speed. 🤔
It also has an three position in/out switch,(center position turns the fan off
) which has always worked and a thermostat that has never worked.🥴
There is also a limit switch that requires cleaning and lubrication and a rain sensor that must also be kept clean.
A photo of your fan with a close-up of the controls would help a lot.
