This is on an '18? Hmmm...
I think it may be possible that the thermostats are calibrated wrong and have a minimum temp higher than your air temp. I'd expect the fans to just run continuously at the minimum-temp setting on the dial, but maybe the thermostat is opening?
40f is likely colder than they designed for, and the fact that the lid motors are working suggests you have power, and the master switches are on. The blades spin freely by hand?
— David
