Old 05-13-2022, 08:41 AM   #1
Thompsons station , Tennessee
79 Sovereign Fan Replacement
Hello everyone. I am currently remodeling a 1979 sovereign. It has three ceiling fan vents and I want to replace them with modern ceiling vent fans. I would like to replace the front and the rear with new fan/vents and the one closest to the air-conditioning with just a skylight type without a vent or fan in it. Can someone please direct me to the correct modern Fans that will fit directly into these not so square rounded off corner ceiling holes or if there is a process I need to go through to remove the current mounting holes in the ceilings to allow installation of the modern fans and skylight. Thank you very much.
Andrew 6159823345
Knuckleberry is offline   Reply With Quote
sovereign
Frig Fan Replacement and How to do Dual Fan TankerIP Refrigerators 14 04-15-2018 12:11 AM
Fan-tastic a good replacement for a vintage fan vent? Globie64 Roof 1 08-23-2015 06:04 AM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Fan-Tastic fan install Gordon Watt Roof Vents, Skylights & Fans 28 08-15-2011 11:41 AM
Fan-tastic Fan installation BobbyW Roof Vents, Skylights & Fans 4 06-17-2002 09:40 PM
