Old 11-29-2023, 03:50 PM   #1
2021 27' International
Baker , Louisiana
Windows sticking to seals
2021 international. Since purchasing used from original owner, the first time we tried opening windows, all of our windows are sticking to the sealing gaskets. So, to release we’ve used a soft plastic paint scraper to smoothly pry the gaskets away from the widows. Once opened , have applied Corning 111 lubricant ( high end non- reactive clear grease ) to all the gasket surfaces. After a week or so ..same problem.
I now just routinely open them at least twice a week and assume this may be a common problem?
Just seeing if anyone else had a thought of something else to use as a lubricant that may be more effective.
Yes it was very Hot in Louisiana.so opening windows in summer is a no no.Sun is brutal.
Mtbyland is offline   Reply With Quote
Old 11-29-2023, 04:07 PM   #2
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
We use a silicone spray on a rag & wipe the seals. I figure if they stick, they don't leak...so it's kinda a good thing!
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 11-29-2023, 05:12 PM   #3
2021 28' International
Knoxville , Tennessee
I've had the same issue and used 303 Protectorant, I think it's called. Check me on the name. It good for many uses, including all the seals around windows. doors, etc..
Gibson3798 is offline   Reply With Quote
Old 11-29-2023, 06:47 PM   #4
2000 30' Excella
Tucson , Arizona
silicone
I used 3 in one RV slide out silicone lube. Windows haven't stuck in a year. Still going.
winston10 is offline   Reply With Quote
Old 11-29-2023, 06:49 PM   #5
aftermath's Avatar
Spokane , Washington
I think the 303 protectant is a great product. I recommend using it on all of your window gaskets.....but.....I installed some of these window poppers and they work, really well. I hope the link below comes in
Poppershttps://video.search.yahoo.com/yhs/s...6&action=click
aftermath is offline   Reply With Quote
Old 11-29-2023, 10:54 PM   #6
2017 28' International
Jim Falls , Wisconsin
303 is recommended. However, even after that they will stick. It seems like every year I use a credit card to slip in between seals and windows to open them. And it isn’t all the windows. Just a few. Probably those that don’t get opened as often.
Daquenzer is offline   Reply With Quote
Old 11-29-2023, 11:16 PM   #7
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
Please be specific as to which 303 product you are referring to and recommending. They have many for various uses and all identified as 303. All solid products in my opinion. But how you use them differs. I personally use three different ones.
So which 303 for what use? The wrong one in the wrong way would not be a happy time...not sure folks trying a window trim sealant would be happy with a tonneau cleaner.
bweybright is offline   Reply With Quote
Old 11-30-2023, 08:23 AM   #8
2019 23' Flying Cloud
Red Bank , New Jersey
Morning Bob. My Flying Cloud manual is specific:
Apply 303 Aerospace Protectant (Airstream part # 44845WR-01) to the window gasket. To apply, spray/pour 303 onto a soft rag or sponge and apply a generous coating directly to the gasket.
rhoatson is offline   Reply With Quote
Old 11-30-2023, 11:00 AM   #9
bcheever's Avatar
2021 22' Caravel
SEATTLE , WA
+1 to the Aerospace 303 Protectant.
We had been struggling with the windows until I read about 303 on the forums and it was a night and day difference. I spray it on the seals once at the beginning of the season and then wipe it off with a rag. And then occasionally again if needed (usually not needed).
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
PS Also a good idea to open your windows frequently. One thing I love about the Airstream is how many windows it has, if you open them all there's always a good cross breeze.
bcheever is offline   Reply With Quote
Old 11-30-2023, 11:33 AM   #10
Genebuilder's Avatar
2017 25' Flying Cloud
Celina , Texas
I’m still looking in my car’s users manual to find out what kind of lubricant I need to apply to keep my windows from sticking to the gaskets. Can some one help me?
I suspect one pays more for his Airstream than his car, but has to suffer inferior, sticking, window gaskets. Can’t say I ever suffered from a sticking automotive window gasket, starting with my 1965 GTO.
Owner alert! Things aren’t getting better. An acquaintance, having just purchased a 2023 Airstream 23 FBT, had to immediately take it in for warranty service. In trying to open a window for the first time, a piece of gasket adhered to the window and tore away from the remaining gasket.
We deserve better folks. We really do.
2017 Ford F150 Lariat 3.5L EcoBoost w/Max Tow
FAA Certificated Remote (Drone) Pilot
Amateur Radio Extra Class N5EAS
Journeying America via the "Blue Highways"
-Be Curious, Not Judgemental…Walt Whitman-
Genebuilder is offline   Reply With Quote
Old 11-30-2023, 02:08 PM   #11
2019 27' Flying Cloud
Yorba Linda , California
Windows stick
I have mentioned several times that I released tension on the windows. To release tension, open the windows and back off the nuts to releave tension, then turn the other nut to tighten the lock paw. Before closing the window, place a dollar bill between the glass and the seal, lock the window. The dollar bill should pull out with a small resistance. Doing this will reduce the opening problem. Yes, this does work!!!!!!!!
soling917 is offline   Reply With Quote
Old 11-30-2023, 02:10 PM   #12
2019 27' Globetrotter
2023 30' Classic
Denver , North Carolina
At Alumapalooza this year the service manager for trailers addressed the proper method for treating the window gaskets with 303 Aerospace Protectant. He mentioned one thing that I had not heard before. After the 303 has been applied let it DRY before closing the windows. He said this would decrease the glass sticking to the gaskets.
Dave S
link2dks is offline   Reply With Quote
Old 11-30-2023, 02:36 PM   #13
Woodway , Texas
Windows Sticking to Gaskets, Poppers
We've been using an older ATM card that I've had since the 80's. It's thick but flexible enough to slide in between the gasket and the window without cracking and works perfectly. Keep it in a box by the door for just those occasions.
emelaich01 is offline   Reply With Quote
Old 11-30-2023, 02:49 PM   #14
North AL , Alabama
I've tried it all: 303 Protectant, Honda Silicone Grease, loosen tension on the seals, etc.
Everything works for a while, but I always end up back outside with a credit card . . .
I wish the window poppers were still available for sale.
Tyler2you is offline   Reply With Quote
Old 11-30-2023, 03:58 PM   #15
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
I found this post for making home-made poppers.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is online now   Reply With Quote
Old 11-30-2023, 11:02 PM   #16
Ahhhh, perfect. Exactly what I was asking for. Thank you. As I mentioned they have a ton of products, all good and I use many and will continue to do so. Knowing which specific for the window seals is great knowledge.
Old 12-01-2023, 08:31 AM   #17
2019 25' International
Washington , Washington, D.C.
link2 - thanks for the additional info regarding letting 303 dry before closing the windows again.
BTW - I use a boning tool to open the windows when they stick; and keep it in the silverware drawer. Here's link showing what it looks like.
https://www.amazon.com/Warmshine-Cre...zcF9hdGY&psc=1
PatLee is offline   Reply With Quote
Old 12-01-2023, 08:49 AM   #18
Mollysdad's Avatar
Yep. I learned from LoLoHo. Its real purpose is to score paper for crafts. I don't have to pry everywhere, usually, a tiny spot near the bottom corner and the window lets go.
Old 12-01-2023, 09:42 AM   #19
2019 25' Flying Cloud
Houston , Texas
I bought the Aerospace 303 Protectant in sheets. Easy to apply and for us has worked well. I carry a plastic automotive trim tool for the occasional sticking window.
DCPAS is offline   Reply With Quote
Old 12-01-2023, 10:19 AM   #20
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Georgetown (winter)Thayne (summer) , Texas & Wyoming
Credit card or plastic lever works fine...tried all the "lubricants". I find this is not annoying enough to install the popper shown, but understand the convenience may be attractive to some. I have found, once you "pry" them open, they are pretty easy to open from inside each day while camping. It seems the longer they are not used, is when they start to stick again!
2017 28' Twin Flying Cloud
Sticking Windows The Colonel Windows & Screens 14 02-24-2017 10:06 PM
Sticking windows Getahobby Windows & Screens 11 08-19-2012 03:17 PM
Windows sticking to weatherstripping Jammer Windows & Screens 2 10-22-2010 08:08 PM
Sticking windows Arlodavy Forum Admin, News and Member Account Info 3 09-05-2009 07:36 AM
problem with windows sticking... safari05-25 Windows & Screens 15 02-04-2007 11:24 AM
