Old 04-19-2021, 03:41 PM   #1
2021 22' Caravel
Bozeman , Montana
Windows Sticking to Gaskets
Hi,
Picked up a new Caravel over the weekend.
The windows keep sticking when closed--they stick to the window gaskets and need to be pried open from the outside. Any suggestions of something to apply to the gaskets so that they're not so sticky?
Brian R. is offline   Reply With Quote
Old 04-19-2021, 03:53 PM   #2
Long Island , New York
303 Protectant wipes:
https://www.amazon.com/303-Protectan...8869263&sr=8-3
https://www.google.com/search?q=303+...=airforums.com
Works great, easy to store container, lightweight, Airstream recommended per threads/posts above, no overspray using wipes . . .
Happy Trails and congratulations on the new trailer!
Peter
Let the music lift you up . . .
Old 04-19-2021, 04:16 PM   #3
Steamguy's Avatar
2019 27' International
Washougal , Washington
+1 on the 303. Also get an old credit card or even better, an old AAA membership card to slip between the glass and the rubber. Zip it around the window, unsticks it in a jiffy...
Steamguy
2019 International Serenity 27 FB
"Live, Laugh, Love"
Click here to go to my blog: I try to add wisdom, not noise.
Steamguy is offline   Reply With Quote
Old 04-19-2021, 04:21 PM   #4
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I sprayed some silicone on the end of a paper towel and then wiped each gasket. After doing it a few times over the first year of ownership I saw the lessening of the gaskets sticking to the windows. Apparently the more the windows are kept open at first, a light layer of fine dust in the air will accumulate on gaskets which will make them less prone to sticking to the glass.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 04-19-2021, 04:34 PM   #5
2002 19' Bambi
Lafayette , California
An old solution to sticky rubber gaskets is rubbing it with talcum powder. Presumably dust has the same effect.
Tim
Tim A. is offline   Reply With Quote
Old 04-20-2021, 05:36 AM   #6
dmassey321's Avatar
2021 33FB Classic
FRISCO , TX
We installed Window Poppers in our Classic and love them. Excellent product.
https://seeyoudowntheroad.com/pages/window-poppers
Dave Massey
2021 Classic 33FBQ; 2020 F250 Lariat 7.3 Godzilla
dmassey321 is offline   Reply With Quote
Old 04-20-2021, 05:52 AM   #7
LNBright's Avatar
2015 20' Flying Cloud
Kingsport , Tennessee
Tim
When I was picking up my AS at the dealership and spent a good long time going through it w/ the tech, he said to use talcum, that silicone isn't good for the rubber, but talc won't hurt it.
I've tried talc'ing it so far, but I'm still getting some sticking, need to try to retalc it and see if I just don't have enough, or what...
_ _ _ _
For when it does stick, what I've found that works amazingly well, is a suction cup:
https://www.amazon.com/HASKO-accesso.../dp/B01JMXKX5M
I'd gotten these (in addition to some other HASKO things, like a paper towel holder and a toothbrush cup): my idea for these was to be able to stick them on the outside to let towels hang-dry, when I don't want them in the AS. (I would not leave them on all the time, just stick them up when needed, then put them back in a drawer.)
So on our maiden voyage, the front, rear, and one of the side dinette windows opened, but the other dinette window didn't. I was trying to decide if I should try my drivers license versus a credit card, when I remembered I had the hooks in a drawer: Wow! No effort or fussing, it just opened it right up.
Wouldn't need to be those specific ones: I'd expect even a suncatcher or anything that has a suction cup to go onto a window would easily lift open a window that has just started to stick. (Now, if they've been stuck all winter, that could be another story, you might need something with more oomph...)
-Leslie
LNBright is offline   Reply With Quote
Old 04-20-2021, 07:00 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
This is a simply, no mess, no cost, no maintenance solution to open a stuck window on your Airstream. This works from the inside without having to get dressed to go outside and pry the bottom of the window. This also works every time and never fails.
Drill a small hole (a little over 1/4") in the bottom of the aluminum screen frame on each window. Take a 12" piece of wooden dowel and put it through the hole in the screen frame. Unlock the window catches and push the dowel against the bottom of the window glass. This will easily loosen the glass from the rubber molding. You can then open the window with the side handles to the desired position.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 04-20-2021, 09:11 AM   #9
2007 22' International CCD
Or get a set of ‘window poppers’. Little spring-loaded pushers that install neatly, permanently and push the windows open from inside. Google for them.
The ‘seeyoudowntheroad’ folks website sells them. Slick and permanent, and the big advantage is it does not leave a hole for the bugs...
Old 04-20-2021, 09:18 AM   #10
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
This is "Normal" apply some silicone grease to the gaskets every once and a while. Make sure it is compatible with rubber - we use "Trident" on Amazon
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 04-20-2021, 10:41 AM   #11
2019 30' Flying Cloud
Grass Lake , Michigan
We installed the window poppers last year:
They work great!
We also lubricate the window seals a couple of times a year.
oldenavy is online now   Reply With Quote
Old 04-20-2021, 11:03 AM   #12
cosmotini's Avatar
2020 23' Globetrotter
Saint Louis , Missouri
Images: 83
I was told by a service tech that olive oil works well. He didn't elaborate on whether it should be virgin or cold pressed. He did say he was told this by a service person at the mother ship.
Dennis
Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 04-20-2021, 11:07 AM   #13
2008 19' International
Windows sticking.
I found putting a small length of dental floss between the window snd gasket when it is closed works great after storing the AS for a while. When ready to open them, slide the dental floss around the perimeter of the window. Doesn’t damage the window or gasket.
ImaTarHeel is offline   Reply With Quote
Old 04-20-2021, 11:29 AM   #14
2017 19' International
Tallahassee , Florida
I've put 303 Protectant on the window gaskets (perhaps not often enough), but they still stick.
I've used a credit card to ease them open but now go at with the classic "bone tool." You can get one at an auto-parts store, cheap.
WhereStream is offline   Reply With Quote
Old 04-20-2021, 11:36 AM   #15
Banks87
2019 28' Flying Cloud
Outer Banks , North Carolina
We use this bike tire tool that we already have on hand for the bikes to unstick the windows. Works great!
Maifede Bike Tire Lever 4 Pack, Strong & Long Lasting Tire Changing Tool for Road or Mountain Bike Tires https://smile.amazon.com/dp/B08MPC1Z...EYEYCS3XADC004
Banks87 is offline   Reply With Quote
Old 04-20-2021, 12:02 PM   #16
2007 25' International CCD
Prescott , Arizona
I use the credit card method. It is quick and easy. Use an old one so you don't have to have a new one sent to you.
Mike
new2trailer is offline   Reply With Quote
Old 04-20-2021, 12:09 PM   #17
2019 27' Flying Cloud
Yorba Linda , California
Well I have stopped using all that stuff and adjusted the tension on the window latch so the seal just seals but does not smash the rubber seal. I open the windows from the inside and have no rubber transfer. It does take a little time to get them right but I can leave the windows latched for months and open them from the inside every time!
soling917 is offline   Reply With Quote
Old 04-20-2021, 12:46 PM   #18
Orangeville , Ontario
Interesting posts! I have always washed the windows and seals in the spring, and applied spray silicone to the seals...... We never have a major window stick issue if this is done. The silicone we use is for car seals.....so don't see why it would be different on an RV. Anyway, my 2c, take it for what it's worth.
Cheers, Scott
farvernugen is offline   Reply With Quote
Old 04-20-2021, 01:29 PM   #19
1999 28' Excella
Lake Mary , Florida
Buy a can of Bees Wax polish,,,,keeps bugs out too!
suncoasteng is offline   Reply With Quote
Old 04-20-2021, 01:43 PM   #20
Pbfec
2019 25' Flying Cloud
jupiter , Florida
Originally Posted by Brian R. View Post
Hi,
Credit card or Hotel room key does the trick. Really easy!
Safe travels!
pbfec1 is offline   Reply With Quote
Sticking Windows The Colonel Windows & Screens 14 02-24-2017 09:06 PM
Sticking windows Getahobby Windows & Screens 11 08-19-2012 02:17 PM
Windows sticking to weatherstripping Jammer Windows & Screens 2 10-22-2010 07:08 PM
Sticking windows Arlodavy Forum Admin, News and Member Account Info 3 09-05-2009 06:36 AM
problem with windows sticking... safari05-25 Windows & Screens 15 02-04-2007 10:24 AM
