Old 05-09-2018, 06:13 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Window Operator Handle Needed
I need a couple of window "lever" operator handles for my 75 Overlander.
Anyone know a source for this part, photo below? I need just the plastic part. Appreciate any advice.
David
Name:	1805 Window Opener 2 (Small).JPG
ID:	310545   Click image for larger version
Name:	1805 Window Opener 1 (Small).JPG
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Link to our 1976 Renovation Project:
https://www.airforums.com/forums/f221...ct-202081.html
Old 05-09-2018, 07:24 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
If you can not find exact replacement, this would be an option.
https://www.amazon.com/uxcell-Cupbor.../dp/B01983KSPG
add edit:
the item you are looking for is cabinet or shower hardware, called a back to back cylinder pull
add edit 2:
Another option would be to purchase plastic dowels, cut to length, drill holes for through bolts, sand the ends round
Alan
Old 05-10-2018, 05:28 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you Allan: Back to back cylinder pull. I'll remember that one. I was going to call it a recoil starter handle for the old lawn mower Your idea of making one from a plastic dowel is good.
I hopeful someone might have a couple from a junk seventies trailer.
David
WBCCI #8607
VAC Region 11
Old 08-02-2018, 02:15 PM   #4
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Handles for Flat Bar Window Operators from 1970s
David, we're reproducing them this summer. But in chrome plate. I hope that works for you.
They'll be VTS-2434. No other real details yet but we'll have them by early October.
Steve
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 08-02-2018, 07:58 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Great to know. Yep they will work for me. Maybe add a touch of class to an old Overlander. I'm very happy you fired up your lathe and made some out of aluminum. Too expensive to build a mold for low volume replacements.
Gotta love Vintage Trailer Supply. I'm a big fan.
David
WBCCI #8607
VAC Region 11
Old 08-06-2018, 04:14 AM   #6
VintageRV's Avatar
1956 22' Caravanner
Even better...they will be cast zinc and chrome plated. We're taking a chance on demand.
Old 08-06-2018, 07:16 AM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I broke one when I removed it from the lever. It is 30 year old plastic that probably sees a lot of sunshine and UV. It was brittle, and when trying to loosen the rusty nut and bolt, the plastic broke on me.
I believe the shiny ones will be a decorative improvement, especially in the galley or dinette areas where they are exposed and not always hidden behind curtains.
When I get my set, I'll do a VTS review on them.
David
WBCCI #8607
VAC Region 11
Old 08-12-2018, 10:46 PM   #8
VintageRV's Avatar
1956 22' Caravanner
We will be grateful for any feedback positive or negative.
Thank you,
Steve
David
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
window operator replacement options GR8DANE Windows & Screens 17 01-10-2011 09:09 AM
2001 window operator w9det 2001 Safari 0 05-14-2009 08:10 AM
Hehr window operator replacement questions 63air Windows & Screens 5 05-21-2008 05:25 PM
'62 Bambi - window operator not attached kamo Windows & Screens 3 08-16-2006 05:34 PM
