Old 05-19-2022, 05:45 PM   #1
Tahoe Vista , California
What type of glue should I use? Window arm knob replacement
So I finally ordered some window arm knobs to replace the missing ones, but they don’t come with the attachment screws. Instead, it says I need to glue in place.
Any thoughts on the best tho of glue to use for this? I really don’t want one coming off while trying to open/close a window. The glue will need to be able to handle heat/cold when in storage as well.
Thanks all!
Double J is offline   Reply With Quote
Old 05-20-2022, 04:17 AM   #2
2019 30' International
Pennsylvania , Pennsylvania
I've found the service guys at Airstream Factory to be an excellent resource. I often email them and ask their advice. In this case, I'd simply do that, and ask them what they use.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is online now   Reply With Quote
Old 05-20-2022, 06:05 AM   #3
2017 19' International
Tallahassee , Florida
What email address will get us to the Airstream service team?
WhereStream is offline   Reply With Quote
Old 05-20-2022, 06:42 AM   #4
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
tel:937-596-6111 fax:937-596-7939. I usually go to this website:
https://support.airstream.com/hc/en-...=5921636758164
Airstream usually responds within 24-48 hours.
The following link can also be used for questions:
https://support.airstream.com/hc/en-us/requests/new
I hope this helps.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 05-20-2022, 09:56 AM   #5
1974 25' Tradewind
Calgary , Alberta
Originally Posted by Double J View Post
So I finally ordered some window arm knobs to replace the missing ones, but they donít come with the attachment screws. Instead, it says I need to glue in place.
Any thoughts on the best tho of glue to use for this? I really donít want one coming off while trying to open/close a window. The glue will need to be able to handle heat/cold when in storage as well.
Thanks all!
Get some small grub screws (8-32?) and a bottoming tap and put the proper threads back in.
Alumineer is offline   Reply With Quote
Old 05-20-2022, 04:20 PM   #6
Napa , California
There is a far better choice, Vintage Trailer Supply sells a chrome knob with a set screw. Expensive, but worth every penny. We bought them for every window, put them on with a dab of Loctite and have NOT had one fall off in 4 years (they fell off continually before, every time we touched them!).
https://www.vintagetrailersupply.com...-knob-vts-294/
Atwebs is offline   Reply With Quote
Old 05-20-2022, 05:23 PM   #7
dznf0g's Avatar
Oswego , Illinois
I installed those metal ones years ago. They are nice, but just like the original ones, they loosen up and spin a bit. Blue loctite fixed that.
Yikes! Back then they were a little over $5 apiece.
Sent from my SM-G950U using Airstream Forums mobile app
-Rich-
What kind of glue should I use to put in a small vista window? megan1968 Windows, Doors, Locks & Vents 2 12-25-2021 09:41 AM
'63 Safari window seals replacement - should I use glue? Johnieappel 1960 - 1965 Safari 5 05-12-2021 10:46 AM
Replacement lower arm and bracket for middle arm and replacement lower arm and bracke snappykelly Awnings 1 02-02-2020 09:47 AM
Knob on the end of the window arm of a 1973 tradewind? moormansmari Windows & Screens 12 02-16-2010 03:15 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
