Some Vista Vues are flat and some are curved (depending on year and model). Some are held in by gaskets in the frame, some are held in place by gaskets and an aluminum insert that goes all the way around (by far the easiest to rebuild). Here was my response from your comment on the blog...
"...if you can *carefully* place a chisel in the crack where the frame will separate and gently tap, you can usually get the frame to open a little (then pry the rest of the way). Also, try first using a “rust buster” type material like WD-40 or PB Blaster and letting it soak into the area with the split and the pin to help loosen up any corrosion or other gunk that might be holding it together.
Hope this helps!
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
