Our new to us 1972 Overlander has water trapped in the passenger side wing window. The PO had caulked this side with silicon, which we are in the process of cleaning off.
Any suggestions on removing this trapped water? Could we drill a small hole in the lower end of the aluminum frame & "wiggle" a wire in between the two glass panes to allow the water to escape?
