Old 07-09-2018, 11:43 AM   #1
1971 29' Ambassador
Cleveland , Ohio
Push arm removal
Hi all,
Wondering how to remove the push arms from the window frame attachment?
It's a 71 Ambassador. I was expecting a C-clip to remove and then pull the bar through, but these are two washers. Is this outer piece threaded into the inner? I didn't want to start wrenching on it and break it off...
Any advice is appreciated.
ID:	316433   Click image for larger version
Clevelander is offline   Reply With Quote
Old 07-10-2018, 09:28 PM   #2
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Push arm removal
Mine have nuts you unscrew. It's a 75 argosy
On closer examination, yours looks like it has a roll pin that you need to push out. Then it should come apart
Matt
rugjenkins is offline   Reply With Quote
Old 08-31-2018, 07:03 PM   #3
Still Dreaming
Manning G's Avatar
1971 29' Ambassador
Sulphur Springs , Texas
I cannot see it on your pictures but it looks like mine on my '71 Ambassador. I have these horrible little c-rings that I really don't know how to take off except to spend about 10 minutes EACH with a little pick digging them out. I've only done one so far and it deformed to the point that I will need to find replacement c-rings. If you find a better solution for getting these off PLEASE post. I will do the same.
Manning
Manning G is offline   Reply With Quote
Old 08-31-2018, 07:21 PM   #4
Still Dreaming
Manning G's Avatar
1971 29' Ambassador
Upon further searching I found the following forum thread. It looks like I will get the clips off the window SOMEHOW and replace them with e-clips. Someone there even had to Drimmel off the "clip".
http://www.airforums.com/forums/f454...on-144731.html
Good luck to us both.
Manning
Old 09-01-2018, 12:01 PM   #5
1971 29' Ambassador
Cleveland , Ohio
Thanks for posting! Looks like some careful work with a Dremel cutoff wheel is in my future.
1974 Soveriegn 31" window push arm aberkemann Windows & Screens 2 02-03-2017 03:50 AM
1975-79 or 84 window push arm stgerdonly Airstream Classifieds 0 03-20-2015 01:17 PM
Looking for window push arm knobs for 1969 Overlander New2Airs Windows & Screens 4 03-01-2014 07:04 PM
Window Crank Arm removal wohtex Windows & Screens 5 04-14-2006 09:23 AM
Looking for push bar tyndalelady Our Community 3 02-02-2006 07:33 PM
