06-05-2020, 12:28 AM
1953 21' Flying Cloud
Lakewood
Material to secure window glass to aluminum frame
Hi. an Airstream repair shop sealed the windows in my '53 Flying Cloud back in 2016 by inserting a bead of some sort of caulk or sealant between the glass and the aluminum window frame. After 3 years, that seal/caul material cracked and failed. I'm going to scrape out the failed seal. Can anybody tell me what seal or caulking material would be a good material for bonding the glass and aluminum?
Many thanks,
06-05-2020, 09:44 AM
1958 26' Overlander
Battle Ground
I used 3M moulding tape on my 58 and its held up for 6 years so far.
https://www.3m.com/3M/en_US/company-...3241071&rt=rud
Make sure the window frame is clean. I wiped it down with acetone.
06-05-2020, 11:35 AM
Lakewood
Harold and Rebecca, Thanks for the guidance. It is much appreciated. Bob
06-05-2020, 01:51 PM
1956 22' Safari
Conifer/Evergreen
When we did our restoration several years ago, I rebuilt all the windows using gasket like they were originally. Here is a link to our page with the window rebuild post.
I believe I ordered the gasket from either VTS or Inland RV.
Shari
06-06-2020, 12:43 AM
Lakewood
Thanks, Shari. I was actually looking at that option, too. Reached out to VTS today, sending a picture of the frame interior - to make sure their early '50s gasket would work. She wrote back saying she didn't think our windows were Heher. Am attaching a photo here. Would be curious to hear if you think these look significantly different from yours. Thanks!
06-06-2020, 12:57 AM
Lakewood
Shari, I just looked through the photos in your link. Your windows appear to be structurally similar to ours. Not sure what the lady at VTS was talking about.
06-06-2020, 06:46 AM
2019 30' Classic
New Milford
, Pennsylvania
3M5200 used by boaters. Expensive, difficult to work with, but if done properly, will not leak or come apart.
06-06-2020, 10:48 AM
2014 30' International
Delphi
, Indiana
window seal
In the boating world 3M 5200 adhesive caulk is often used. Have acetone and a rag close by for clean up. Tape off the edges for a smooth line. 3M 5200 is not often used by the very experienced boater because it is nearly impossible to remove/clean-up after it sets. You can get either 24 hour set for 7 day set. Often times 3M 4200 is used instead as it seals well, is difficult to remove cleanly but can be done.
06-06-2020, 12:45 PM
1964 26' Overlander
Milton
, ON
I used TremPro 644 to attach the vista view window glass to the aluminum frame. One of the suggested uses is as a glass to metal adhesive. It seems to be standing up well.
06-07-2020, 12:09 AM
Lakewood
Good idea. And I have a tube of that. Though I think I may have cut the nozzle too wide!
06-07-2020, 12:22 PM
1964 26' Overlander
Milton
, ON
When I need a small bead of caulking I'll put some into a syringe. It makes it a lot easier to control. You can buy various sizes of syringes through Amazon. I think the ones I have are 30 cc. I find it keeps in the syringe pretty well too, especially if you can eliminate the air bubbles as much as possible. I seal the syringe and partially used caulking tubes with hot glue.
06-07-2020, 01:08 PM
1956 22' Safari
Conifer/Evergreen
I agree, they do look like ours. Generally the windows in mid-50's Airstreams are all the same. Regardless, the same gaskets should work...what she may have been looking at was the failed caulking hanging around & trying to match that.
Shari
