Old 12-12-2023, 09:43 AM   #1
2022 25' International
Boca Raton , FL
Leaking Window Gasket
We have a 14 month old International 25FBT. We don't get to use it as much as we'd like yet as I have not retired. Our last trip we noticed our mattress on the curbside twin was slightly damp. After investigating we think we found the culprit. Our local Five star dealership told us sorry, not covered.
The leaking window is the Curbside bedroom window above the porthole window. It opens. When we did water testing around that area, we found water was entering through the gasket at the bottom of the window and splashing over the aluminum channel.
My question is, Is the placement of the gasket with the seam at the bottom of the window standard. Should there be enough of a gap that water can leak through?
Name:	Curbside window 1300.jpg
ID:	439498   Click image for larger version
Name:	Window GAsket 1300 .jpg
TMcAna is offline   Reply With Quote
Old 12-12-2023, 10:29 AM   #2
Boxite's Avatar
2008 22' Safari
I’m not convinced that is the source of the leak… but in any event…it certainly SHOULD be a warranty item.
Personally, I’d caulk it myself either way.
Old 12-12-2023, 01:53 PM   #3
2019 30' International
Pennsylvania , Pennsylvania
Two comments.
1. If it is the upper window that's leaking, you can tighten the closure mechanisms to pull the window tighter to the gasket. The nuts to do so can be reached from outside.
2. Look closely at that porthole window. Make sure water isn't seeping in at the bottom, between the glass and the aluminum trim piece. I've actually caulked all of my non opening windows on my rig.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 4:30 rear Leer Topper Ruby Red
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 12-13-2023, 12:57 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
I seriously doubt that the small gap you're seeing is the source of the water leak.
First, the water would have be be blown in there with lots of force to get up over that aluminum lip, and then past the interior lip on the aluminum. Other than with a high-pressure garden hose I don't see this happening from rain.
Second, when the window is closed and pulled tight, that little gap should be virtually pushed together and closed. Are you sure that the closure latches are adjusted tight enough?
My hunch is that the water you're seeing is possibly condensation on the inside of the window, or more likely, coming from somewhere much higher up like an exterior marker light which is leaking. Leaks from above will flow inside the skin until they reach the window frame and then enter the trailer, usually looking like the leak is actually coming from the window itself when in reality its source is higher up.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 12-13-2023, 07:57 AM   #5
Boca Raton , FL
Understood. Our first Airstream was a 2008 Safari Sport! I am just annoyed that I have had more trouble with this brand new International in 14 months than I did with my 14 year old Sport.
Old 12-13-2023, 08:03 AM   #6
Boca Raton , FL
Originally Posted by majorairhead View Post
Two comments.
Yes, It is the upper window. The actual water location we found inside the trailer is on the porthole window ledge.
We have water tested the entire area and the only place we found moisture was
at this spot so far. We tested 10 minutes of water at the awning connections, front curved seams and the lights. We also worked water around all of the window frames.
We will probably seal the gap, and then retest and watch.
Old 12-13-2023, 08:08 AM   #7
Boca Raton , FL
I agree that it takes some presssure to get the water over the lips. We did alot of testing and will continue to monitor. Although I did not include a photo of the seal gap when the window is closed tighly, it is still there and significant. My thought is living in Florida, our last trip was through a multiple hour downpour at Highway speeds.
We will seal the gap, retest and keep a watch.
Old 12-13-2023, 08:22 AM   #8
1994 25' Excella
If you're going to reseal the gap, there is a black silicone specifically designed for use around windshields. I've used it in the past to repair tears/gaps in window seals of a vintage vehicle. If you cut the opening to the smallest possible, you should be able to squeeze some into the gap and then tool it to shape easily.
Richard
11018
Old 02-05-2025, 09:39 PM   #9
Morgan Hill , California
I'm having the EXACT same issue on a 2020 Globetrotter 27FB. Same window (passenger front window) that is leaking and is wetting the mattress. I examined the window carefully and it is identical to what you are experiencing.
I'm wondering if the leak is getting somewhere higher up, getting stuck in the window channel and leaking into the mattress.
Was wondering if you solved this mystery?
ai-traveler is offline   Reply With Quote
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
Leaking A/C roof gasket? ArtStream Furnaces, Heaters, Fireplaces & Air Conditioning 1 10-28-2006 11:30 AM
Leaking door gasket TrailerTramp Doors & Locks 5 05-12-2006 01:24 PM
window gasket replacement JayClay Windows & Screens 3 05-05-2003 09:35 AM
Source for window gasket jaiman Windows & Screens 2 09-07-2002 09:16 PM
