Hehr Window Issue Open/Close
The lower panel on one of the windows on my 2004 Safari will no longer open or close using the knob. I can open and close the window manually from the exterior of the RV.
Removed the knob and turned the shaft using a wrench. Shaft rotates lock to lock but the window does not move.
It appears that the open/close mechanism is damaged. Anyone on the Forums had the same problem? Looking for solutions i.e. replacing the open/close mechanism rather than replacing the entire window.
PS. Can't find the model number for the Hehre windows. Anyone have that?
THNX
