Old 01-26-2018, 12:17 PM   #1
1976 31' Sovereign
Jacksonville , Florida
Has anyone attempted vista view separation?
Iím talking about the one you have to drill out from the frame. Iíve got mine out and have drilled out the 4 rivets holding the sides together but am stuck at this point. Nothing seems to work as far as separating the frame from glass. Iíve used mallet and wood, spreader clamps, lubricating oil... Iím not sure where to go from here. Can anyone help me think outside the box?
Andy Moreau is offline   Reply With Quote
Old 01-26-2018, 01:39 PM   #2
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Try a little heat, carefully. Also, use a good penetrating oil like Kroil. You may have to let it sit for a day or so. I did all four of mine. There are steel bars that hold the two frame halves together. They rust and sometimes don't come out easily. I had to cut a couple of these out with a hack saw, and machine out the remainder. You can buy new bar stock to replace them.
youngpeck is offline   Reply With Quote
Old 01-26-2018, 02:00 PM   #3
1976 31' Sovereign
Where are the bars located? Right where the separation point is?
Old 01-26-2018, 03:55 PM   #4
youngpeck's Avatar
1976 25' Caravanner
Yes, you are right. Here are four pictures of one of my vista views during removal and disassembly. The first picture shows the window just removed from the body. This is one whose bars connecting the two frame halves had to be sawed out. The middle two pictures show the bar as having been sawed. From there it was a matter of grinding out the remaining bar material and inserting new bar stock. I had to drill new holes for the rivets but once the channel for the bars is cleaned up it's not hard to do at all.
You may not have to do this. The bars on the other three windows came out after repeated soaking with Kroil and careful application of heat.
ID:	303047   Click image for larger version
ID:	303049   Click image for larger version
Old 01-28-2018, 08:33 AM   #5
1976 31' Sovereign
Did you put them back as double pain or did you go single? And when you put new rivets in the holes, what type of rivets did you use? Im not sure how a buck rivet would work in this location.
Old 01-29-2018, 07:24 AM   #6
youngpeck's Avatar
1976 25' Caravanner
I replaced them as originally installed, that is double-paned. I used new gaskets, and used several layers of butyl tape in between the panes to achieve the proper distance between panes.
You are right. You can't use buck rivets when replacing the bars in the frame. I used regular all-aluminum blind or pop rivets. They really just have to hold the frame together until you reattach it to the shell. By the way, I smeared some electrician's aluminum anti-oxident on the bars when reinserting them into the frame, both as a lubricant and as a guard against rust.
Has anyone made a video vista repair? Andy Moreau Windows & Screens 0 12-05-2017 06:09 PM
New water heater vs attempted resurrection of a Bowen/Atwood G6A2 Savage68 All Argosy Trailers 3 06-20-2013 09:11 AM
Vista View window repair/replacement 83Excella Windows & Screens 14 06-06-2013 05:38 AM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
