Old 04-14-2017, 02:10 PM   #1
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Front Window Rock Guard
Our "new" 89 Excella 29 has a severely scuffed center front window guard (a PO poorly removed red numbers).
Is this dark grey piece a simple plexi that I could replace or is it some exotic that I must buy?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
frjeff is offline   Reply With Quote
Old 04-14-2017, 02:16 PM   #2
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Originally Posted by frjeff View Post
our "new" 89 excella 29 has a severely scuffed center front window guard (a po poorly removed red numbers).
Is this dark grey piece a simple plexi that i could replace or is it some exotic that i must buy?
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 04-14-2017, 03:49 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
First order of business is to see if you can get one of the end frame pieces off. They tend to corrode fast to the corner angles but patience may work. Once that is off you should be able to slide the current piece out and take it to a plastic shop as a template. You may have to spread the upper and lower frame pieces to aid in removing the glass.
Any sheet plastic distributor should be able to supply what you need.
2004 Excursion 4x4
Old 04-14-2017, 03:50 PM   #4
Fr Jeff
frjeff's Avatar
1989 29' Excella
Saginaw , Michigan
Or, might I be able to simply cover it with an opaque "smoked" sheet like they use on certain window tinting. Plexi is intact with no cracks, so just want to cover the scuffed area where the numbers can be seen with shadow of them remaining. Purely aesthetic.
Fr. Jeff
2016 F150 Ecoboost
1989 Excella 29
Old 04-15-2017, 07:09 PM   #5
fwjumper's Avatar
1998 34' Limited
Alto , Georgia
Take the frame apart and flip it over if the backside still looks ok.
fwjumper is offline   Reply With Quote
Old 04-15-2017, 07:17 PM   #6
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Use UV resistant Lexan (polycarbonate). It is easier to work with, lasts longer and harder to crack.
It might be worth trying some plastic restorer like they use on headlights.
Cheap Front Window Rock Guard Hotlead Windows & Screens 5 08-14-2019 10:45 AM
28 FC front window rock guard front center window dayner Windows, Doors, Locks & Vents 0 08-29-2015 07:41 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 08:32 AM
Front window rock guard rubber... are they seals? Gator113 Windows & Screens 7 05-30-2010 03:52 PM
rock guard/front window evelitalian Rock Guards, Segment & Window Protectors 2 04-21-2008 06:34 PM
