Old 05-15-2021, 11:00 AM   #1
ITSNO60's Avatar
Tucson , AZ
Does Reflectix need to be hemmed?
Cutting Reflectix for the windshield and side windows, roof vents. Can I leave the edges raw or will it begin to separate?
Brian
ITSNO60 is offline   Reply With Quote
Old 05-15-2021, 11:36 AM   #2
dznf0g's Avatar
Oswego , Illinois
Mine are over 10 years old, and although becoming a bit crumpled on the edges, they have not separated at all.
-Rich-
Old 05-15-2021, 12:30 PM   #3
ITSNO60's Avatar
Tucson , AZ
Thanks, that saves me a lot of work!
Brian
Old 05-15-2021, 02:05 PM   #4
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Summerville , South Carolina
You could very easily "hem" the cut edges with some thin metallic tape like some people use to seal joints on flex air ducts. it is thin and has great adhesion on metallic surfaces. It might give you a more finished look and prevent the edges from any fraying over time.
Just a suggestion.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 05-15-2021, 04:02 PM   #5
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
We use the Reflectix on our coach to keep the heat buildup down, especially when parked broadside to the sun. But, I never liked the looked of it showing through all the windows (we have LOTS of windows on our coach.)
My solution was to use 3M adhesive to stick white fabric to the outer side of the Reflectix. The glue wasn't making a great bond, so I finally gave in and used the zig-zag setting on the machine to make a 'hem' all the way around all the pieces. That did the trick.
I know, the white fabric reduces the amount of sun that the material can bounce back. It looks great though, so it's a keeper.
Okay - why do I mention all this? Two reasons. First if you do want to hem the Reflectix a wide & long zig-zag is the way to go. Straight stitching creates a tear line and one good pull in the wrong direction and the stuff rips like the top of an Amazon bag.
Second, after running the zig-zag stitching all the way around the edges I found that it was much easier to put the stuff in place. The raw edge won't unravel, per se, but it isn't the most handy edge to work into tight places.
So if you have difficulty inserting your cut pieces of Reflectix into the windows you might consider doing the zig-zag around the edges.
1994 Excella 25
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is offline   Reply With Quote
Old 05-16-2021, 08:40 PM   #6
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Some photos would be very helpful.
Thanks, Dan
Old 05-17-2021, 06:14 AM   #7
1994 25' Excella
Thanks, Dan
Kind of difficult to get a good picture of the stitches... It's just a row of the widest zig-zag stitches my machine can do all the way around the edges.
Due to the tinted windows, you cannot see the Reflectix from the outside. However, before I put on the white liner it showed through, which is why I put on the liner.
Attached to the windows with suction cups.
I left the silver showing on the inside, because if the Reflectix is in the windows the drapes are closed. Click image for larger version
ID:	395635Click image for larger version
1994 Excella 25
Reflectix Reflective Insulation toastie Upholstery, Blinds, Walls & Interior Finishes 33 01-18-2014 05:11 PM
Reflectix Insulation under the belly pan? littlebird Winter Living 9 06-07-2013 04:13 PM
Factory tour ... Reflectix under subfloor? Zstream Repairing/Replacing Floor &/or Frame 4 07-30-2008 05:01 AM
Reflectix in windows davidz71 Windows & Screens 12 07-16-2008 11:53 PM
Reflectix Foil Insulation / Installation Dan Clayton General Interior Topics 2 03-29-2008 10:23 PM
