Old 09-16-2020, 04:14 PM   #1
2018 19' Flying Cloud
Newport , Washington
Cracked Window Rock Guard
My curbside window rock guard took a hit from a rock thrown by a passing car. There is a very small pin head sized chip on the outside. When viewed from the inside however, there are 3-4 cracks emanating outward. These cracks do not go all the way through to the outside.
I've searched and found multiple threads on the topic which contain conflicting suggestions for a cure. I have two questions:
1) If I do nothing are these cracks likely to grow? Previous postings are split about 50/50 on this question.
2) If they are likely to grow I will drill small stop holes at the end of each crack and apply a solvent to "weld" the polycarbonate. The question is what solvent would be appropriate? Some previous postings suggest acetone and other postings say that will cause the polycarbonate to shatter.
I don't have $600 laying around so replacing the panel is not an option.
Thanks for your thoughtful responses.....
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 09-16-2020, 04:32 PM   #2
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
Following. Iíve one going too.
Leilanisteve is offline   Reply With Quote
Old 09-16-2020, 04:40 PM   #3
2018 23' Flying Cloud
Savoy , Texas
I drilled the small holes then applied supper glue.
SpinWhite is offline   Reply With Quote
Old 09-17-2020, 03:21 PM   #4
Does anyone see a problem with using this stuff?
https://www.amazon.com/Weldon-Applic...0377618&sr=8-2
Dale & Jane
Old 09-17-2020, 03:57 PM   #5
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
possible to do Rock Chip repair at any auto Glass shops?
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 09-17-2020, 04:17 PM   #6
dznf0g's Avatar
Oswego , Illinois
First off, unless things have changed, they are not polycarbonate, but rather plexiglass. A long time ago, there was a discussion about replacing the smoked material only.....by buying sheets locally.
The debate was whether one could use polycarbonate, or would the bend result in breakage?? A large oven would help, but who has one big enough??
My star cracks have never run, and some are 7 or 8 years old. One of these days, I will procure sheets of plexi and disassemble the frames and replace. Conventional wisdom was that plexi can make the bend with some prudent heat gun help.
-Rich-
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 03:00 PM
Cracked Plexi Rock Guard Roadtech Rock Guards, Segment & Window Protectors 40 08-28-2016 08:23 AM
Cracked window rock guard Edistobob Windows & Screens 5 08-06-2014 08:08 PM
Rock Guard Solar Standard Front window guard ChrisseasCC Windows, Doors, Locks & Vents 1 07-31-2014 07:32 AM
Cracked side rock guard Argy 78 Rock Guards, Segment & Window Protectors 6 03-22-2012 08:59 PM
